In the past, on more than one occasion, two of us have moved a ML7. But it can be unwieldy, if you do not take into account the offset weight of the motor.
Positioning the Tailstock and the saddle will help to balance the lathe in one plane.
If you lift it with a sling, be careful about putting a sling behind the chuck. You are putting part of the weight onto the Headstock bearings.
My inclination would be to disturb as little as possible, even trying to move the lathe with the raising blocks still in place.
