Myford Super 7 Mk1 Leadscrew help
Home › Forums › General Questions › Myford Super 7 Mk1 Leadscrew help
  • #308979
    Piero Franchi
      @pierofranchi37209
      Hi Just
      I am on the last legs of a full restoration on my Myford super 7 Mk1 (see my photos in my profile)
      One of the last things I will be doing is fitting the leadscrew,
      (I have a myford super 7 Mk1 with screw cutting gear box )
      I have use of an other lathe (colchester bantam 1600) and was thinking of buying a acme all thread and machining the ends my self.
      being a Mk1, the leadscrew does not go all the way through the gearbox.
      so my question is, what is the thred, pitch etc ill need and where should/could I buy it from
      Kind regards
      #25395
      Piero Franchi
        @pierofranchi37209
        #308983
        JohnF
          @johnf59703
          Piers, try this link, not sure where you are but somwhere in my "stores" I have a Myford lead screw but for a much later machine than yours. Pm me if you cannot get fixed up with te link John
          http://www.abssac.co.uk/p/Precision+Lead+Screws/ACME+Leadscrew/101/#.WXm0ErHTWhA
          Also see this thread on this site
          http://www.model-engineer.co.uk/forums/postings.asp?th=65338
          Edited By JohnF on 27/07/2017 10:38:22
          Edited By JohnF on 27/07/2017 10:40:59
          #308984
          John Haine
            @johnhaine32865
            Standard pitch for the Myford is 8 tpi. I think the diameter is 0.75". Acme thread form. I assume that you have not converted the machine to metric – if you have then you could improve on Myfrod's "metric" conversion by having a 3mm pitch leadscrew rather than 3.175.. mm!
            #309039
            Piero Franchi
              @pierofranchi37209
              No, not metric
              most of the intended work is going to be imperial
              John F I will pm you now
