"just wondering, Do you guys use the compound slide (set at 90deg) to move the cutting tool along the work or do you use the carriage"
I think some confusion has arisen here. As Piero has a gearbox equipped S7 then he must have easily variable power feed via the leadscrew to the saddle. What he doesn't have is powered crossfeed. What he is talking about is using the compound (topslide) for facing cuts not longitudinal.
Piero my answer is use the crossslide for tranverse movement of the tool, and leave the compound set parallel to the lathe bed.
"will turning the lead screw NOT also turn my gears inside of my gear box ???"
You will find that if you move the lever on top of the gearbox to around the centre position there is a neutral point where the gearbox is not engaged. The leadscrew handwheel is helpful in finding this point as you can turn it whilst moving the lever until the handwheel rotates freely. Turning the handwheel while engaging the top lever in any of its 3 positions is also helpful and makes the gearbox mesh easily. Of course you should never move any of the gearbox levers when under power.
I hope I have understood your question correctly and this is helpful
Edited By Robbo on 06/09/2017 09:56:14
