Hi All, I have a Myford Super 7 lathe. I wanted to clean up a thread so engaged backgear to get an appropriate speed. I engaged the backgear lever in its upper position, released the backgear key, as I have done many times before. I released the clutch, and the spindle did not turn, while the gears made a graunching sound. Checked everything was set properly, but still the same result. I have checked all relevant gears and can see no missing/broken teeth. Confession time: I have in the past engaged backgear to remove chucks before I knew better, but, as I said, no teeth were missing or appeared damaged. The only thing I can think of is the backgear lever is not lifting the gear high enough to engage teeth on spindle gears. Has anyone out there had this problem? All suggestions welcome. Cheers, Andrew
