Myford Super 7
Myford Super 7
Home › Forums › Beginners questions › Myford Super 7
  • #10140
    Geoff Leake
      @geoffleake47800
      Slipping clutch
      #460731
      Geoff Leake
        @geoffleake47800
        Hi, I'm building a classic/special motorcycle and need to turn some relatively uncomplicated parts. I've therefore purchased an old Myford Super 7 lathe, but I've not used any workshop machinery since being at school some 55 years ago! To say I'm a complete novice is a massive understatement. Nevertheless, I took it apart to clean and tidy it up and all seems good, there don't appear to be any broken or worn parts. But having reassembled it, the clutch is slipping. Try as I may, I'm not capable of adjusting it to stop it slipping, so it's not usable in its present state. I guess it's a fairly simple matter to the experienced Myford user but that's definitely not me. Can anybody please help?
        #460869
        Kiwi Bloke
          @kiwibloke62605
          I'm pretty sure that you can find a manual for the Super 7 on the 'net (I haven't looked for one, having an old-tech printed one here…). Let's assume that there is indeed nothing broken or missing, and that it's all gone together as intended.
          Clutch adjustment is by loosening the hex nut in the middle of the bronze 'clutch plate' at the left end of the assembly. This allows the central 'push rod' to be turned relative to the clutch plate, into which it is threaded. Clockwise reduces clutch clearance. Between 45 and 90 degrees of anticlockwise rotation of the push rod from the 'no-clearance' position gives the right amount of movement to disengage.
          So, move the clutch lever to the disengaged position (push rod moves to the left, against spring pressure), adjust the pushrod until there's clutch contact, than back it off (anti-clockwise) between 45 and 90 degrees, to give clearance. Lock with nut.
          'Push rod' is possibly misleading terminology. The clutch compression spring bears on the larger-diameter 'head' of the rod (pushing the rod to the right), thus pulling the bronze plate to the right, into engagement. The 'push' is to disengage the clutch.
          Hope this helps.
          #460884
          Maurice Cox 1
            @mauricecox1
            Geoff may have the older version of the Super 7, which has an expanding clutch ring inside the cone pulley. This requires a screw pug to be removed from the bottom of the grove of one of the larger steps of the pulley. Then, holding the cone pulley still, the interior is rotated until a hex grub screw appears. This is a locking screw. It has to be removed to expose the head of the adjusting screw beneath. No wonder they changed it!
            Maurice
            #460885
            Steviegtr
              @steviegtr
              Yes & the old type had a tendency to snap the cast ring in half. Not available any more. A friend brazed his back together & it is holding fine.
              Steve.
              #460906
              Geoff Leake
                @geoffleake47800
                Morning guys, Thank you all for your prompt response, very much appreciated. I'll digest your comments and check things over as you suggest. Having said that, I'd like to send you an image of my clutch but I've not worked out how to add an image to this message. So I'll reply to your individual email messages, attaching the image, which will let you see the type of clutch I have. Thanks again.
                #460909
                Sandgrounder
                  @sandgrounder
                  Years ago I aquired a S7 Mk1 with the old style clutch, it didn't work as a clutch because the "push rod" or " actuating rod" running down the spindle centre was missing, however the previous owner had put a long bolt M10? in it's place and tightened down the adusting screw, this locked the pulley to the spindle, result no clutch action but at least it worked as a lathe.
                  bricky
                    @bricky
                    Geoff,The headstock on the early S7,s has a oil resevoir with a circular sight glass on the front of the spindle if so you have a lathe between 52 and 59 I think and it will have the old clutch.There is a diagram for the clutch on a previous post and as Maurice has said be aware of the double screw .
                    Frank
                    #460931
                      Hi Geoff,
                      Instructions on how to post photos here.
                      You said 'To say I'm a complete novice is a massive understatement. Nevertheless, I took it apart to clean and tidy it up and all seems good, there don't appear to be any broken or worn parts. But having reassembled it…'
                      May I take the opportunity to repeat a bit of advice? When a novel toy is acquired, whether second-hand or brand-new, beginners should resist the temptation to strip it down. It's the devil trying to lead you astray!
                      A full strip-down is a good way of making exciting new problems before the owner knows what he's doing, or what to look for, or understands what matters and what doesn't. Be aware that a dirty used machine could be in excellent condition. If it ain't broke, don't fix it.
                      Nothing wrong with starting with a light clean and lube job, but don't do anything intrusive.
                      First turn the chuck by hand to make sure nothing's jammed and the controls work as expected. Take notes, don't attempt to fix anything yet.
                      With second-hand machines, carefully inspect the electrics looking for damaged cables, broken switches – anything shocking must be fixed. In particular make sure the machine is earthed back to the plug before plugging in.
                      If a jam is found, identify the cause and fix it. (Depending on what it is, may be a good idea to get forum advice. Like as not it will be obvious.)
                      When the machine turns freely, next step is to power-up. This may reveal motor or bearing trouble, again take notes rather than leaping in. Let the lathe run for several minutes and confirm nothing gets hot. Listen for harsh noises, knocking, rhythmic changes, anything that sounds suspicious.
                      At this point review the list. With luck it's a blank page! Don't fret if several concerns appear – many lathe faults don't matter much, or are easily fixed.
                      Assuming the motor spins the chuck OK, now is the time to cut metal. This is the best way in my opinion to identify serious faults and maladjustments like loose or wonky gibs. With a sharp tool, try facing and turning down a metal rod. I recommend brass to start with because it's forgiving. Avoid testing on scrap or DIY store metal because many alloys don't machine well. EN1A and EN1A-Pb are good to cut, otherwise look for metal where the spec mentions 'free-cutting' or 'good machinability'. Screw-cutting is another good test, but may be beyond a beginner.
                      All being well, the machine will produce straight cuts along and across the face with good finish. Tapers and poor finish will need research as will stalling, chatter, vibration, etc. Again, write a list: the fault may be the operator, cutting tool, or material rather than the machine.
                      Don't be afraid to ask on the forum – there are no stupid questions! Also, Sparey's 'The Amateur's Lathe' – is excellent.
                      Provided it works without serious concern, use the lathe for several weeks to get a feel for it and how well, or badly, it works. Now, the owner is better placed to start fixing things, and to judge what matters and what doesn't. The more experience the better – after a year or two it becomes much easier to get results even out of difficult metals and wonky machines. It's also much easier to identify faults and to gauge how difficult or costly they will be to fix. And to know your own limitations – I'm still learning after 8 years…
                      Enjoy!
                      Geoff Leake
                        @geoffleake47800
                        Morning Dave,
                        Thanks for your very informative response and for your advice. Point taken about “A dirty machine could be in excellent condition”. And I’ve taken all of your other comments on board too.
                        I have to say that apart from this clutch niggle (niggle to an experienced person is all I suspect it will turn out to be), it seems fine with all the gib screws adjusted and all lubrication points attended to. Nothing appears to be jammed, the bearings are running freely and do not appear to be worn. There are no nasty metallic noises, although the running gears do tend to whir somewhat.
                        I’d very much like to have a go at cutting metal and “enjoy”. But until I can get this clutch to grip the taper on the inside of the vee pulley, that’s not possible unless I ignore the clutch adjustment and manually tap it home into the taper, thus operating a direct-drive arrangement without the clutch. I’m not happy to do that.
                        Geoff
