Myford raising block thread size
Home Forums Help and Assistance! (Offered or Wanted) Myford raising block thread size
  • #282970
    rik arry
      @rikarry
      Hi does any one know the inside thread size for the leveller in the myford s7 ml7 raising block
      thanks in advance
      rik arry
        @rikarry
        #282975
        Robbo
          @robbo
          There is no thread inside the levelling screw, the bolt passes through it.
          The external thread on the levelling screw, and so for the hole in the block, for half the thickness of the block, is 9/16"BSF.
          The lower half of the hole in the block is 5/16 BSF for the fixing bolt.
          #282977
          rik arry
            @rikarry
            Great thanks for that winkyes
            So to mount on a bench would i be better getting 5/16 BSF threaded rod as im not sure the standard studs would be long enough to go through a 30mm thick bench
            #282978
            Robbo
              @robbo
              The standard studs will no way go through 30 mm. The bottom thread is only just long enough to go through a standard Myford steel cabinet. Threaded rod is a quick way out and leaves you plenty of room to get it right.
              #282984
              Allan B
                @allanb
                And in my case wasn’t quite long enough for the cabinet and myford floor stand, 9/16 is almost M8 so I just ran an M8 tap through because I had M8 threaded bar in stock 😀
                Allan
                #282993
                rik arry
                  @rikarry
                  Posted by Allan B on 07/02/2017 23:17:52:
                  And in my case wasn't quite long enough for the cabinet and myford floor stand, 9/16 is almost M8 so I just ran an M8 tap through because I had M8 threaded bar in stock 😀
                  Allan
                  I think 5/16 is almost M8 (7.9)wink
                  #283011
                  Allan B
                    @allanb
                    You are right, that’s my brain not working late at night 😕 I was just thinking of the pattern parts that I have just put onto mine, thinking about it I don’t think you would even get 9/16 through the base of the myford lol
                    Allan
                    #286637
                    Andrew Green 8
                      @andrewgreen8
                      How do I place a wanted ad please
                      #286653
                      Robbo
                        @robbo
                        A strange thread to put your question?
                        Answer
                        Go to and click on "classifieds" about 1/2 way across the black bar at top of home page.
                        A template will come up – at top left it has For Sale/Wanteds
                        Click on Wanteds
                        It will show you a list of current ads, but at top right click on "new ad" or whatever it says there
