myford motor
myford motor
  • #32942
    Terry olds
      @terryolds52232
      myford s7 motor repair
      #291505
      Terry olds
        @terryolds52232
        Can anybody help with who does motor repairs in or around Bromsgrove.
        #291519
        Simon Williams 3
          @simonwilliams3
          Try Kidderminster Rewinds Hoo Farm Ind Est 01562 751820.
          No connection, just a satisfied customer
          Rgds Simon
          #291529
          John Stevenson 1
            @johnstevenson1
            Don't bother.
            Far, far cheaper to replace the motor than have it rewound. Anything below 15Kw is now cheaper to replace.
            If you have single phase motor problems then look to replacing it with a 3 phase motor and Inverter [ VFD ] you will never look back.
            #291536
            Mike Poole
              @mikepoole82104
              I had to have a central heating pump rewound because I could not shift the nuts on the base, 24" stillsons with an old fork stanchion would not shift them and as it was a bit cold without heating a 24hr rewind seemed worth it but a bit pricey compared to a new pump. I think the boiler was over 25 years old when it got replaced so two pumps in 25 years didn't seem bad. SEW eurodrive sell stators as a spare part and do not recommend rewinding especially in applications where two motors are working as a pair, they reckon a rewound motor is 5-10% different from a factory part. For a Myford a new motor is not expensive and as John says a good opportunity to go for the inverter option unless your motor is 3 phase already.
              Edited By Mike Poole on 31/03/2017 21:55:32
              #291538
              John Haine
                @johnhaine32865
                Terry, for what machine do you need a motor? I have a motor from off my VMB which I replaced with 3 phase, I'm happy to sell it for a fair price. PM me if you're interested.
                #291545
                not done it yet
                  @notdoneityet
                  At a guess, it would be a myford s7 motor?smiley
                  #291568
                  Brian Oldford
                    @brianoldford70365
                    If you do choose to go down the three phase/VFD route these people are very helpful. https://inverterdrive.com/
                    No connection etc.
                    #291583
                    Speedy Builder5
                      @speedybuilder5
                      Back in the 70s, I re-wound several single phase motors, I still use a couple of them 40 years later. But I am not so sure that I would want to do them now as the skin on my knuckles has worn a bit thin.
                      BobH
                      #291855
                      Terry olds
                        @terryolds52232
                        Thanks for all the info..working on it
