Myford ML7 Bearings
Myford ML7 Bearings
Home › Forums › Help and Assistance! (Offered or Wanted) › Myford ML7 Bearings
  • #315370
    Fergus Davidson
      @fergusdavidson50660
      Hi I have just bought a Myford ML7 and I want to know the maximum safe speed I can run it on white metal bearings. Thanks in advance
      #33064
      Fergus Davidson
        #315410
        Robbo
          @robbo
          The "factory standard" top speed is 870 rpm, using the larger of the 2 motor pulleys available with the machine, and a single phase motor of 1420/1450 rpm. I forget the pulley size, but something around 2¼". Somebody will tell us.
          Higher speeds are used by those who have fitted 3-phase motors with speed control, the important thing is to ensure plenty of lubrication through the oilers at high speeds.
          #315790
          Fergus Davidson
            Thank you for the reply. That's really helpful.
