Hi all,
I am finally getting around to doing this, having bought a Myford M countershaft. As I have mentioned before the motor I am using is a 2800rpm motor and the countershaft has a 9" A section pulley on the end (plus an 8" one). I am thinking of using a 2 1/4" driver pulley on the motor, which will give a countershaft speed of 700rpm. I know this is a touch higher than the usual 600rpm, but I will have PWM control to reduce this down to the required speed, as well the belt changes on the mandrel and the back gear.
Is there likely to be any issues with going from 2 1/4" to 9" in terms of belt grip, or should that be ok? Any minimum pulley distance to aim for?
Many thanks,
James
