Myford Headstock bearings
Home › Forums › Manual machine tools › Myford Headstock bearings
  • #540217
    Bootlegger Blacky
      @bootleggerblacky
      Hello,I have a Myford ML7. That requires new headstock bearings.I assume it has the original soft spindle,so …what do I need? As these are no longer available,can I use oilite off the shelf bearings,or bronze?or am I missing a trick?thanks in advance.
      #14230
      Bootlegger Blacky
        @bootleggerblacky
        Thanks
        #540219
        Andrew Tinsley
          @andrewtinsley63637
          RDG /Myford do a new hardened shaft and bronze bearings. But at a price! The old white metal bearings are extremely thick and they can be re-scraped. The shaft may well need a skim, but you can scrape the old bearings to suit. It will lower your centre height a touch, but who cares when the refurb will cost you nothing.
          I hoarded the last set of new white metal bearings in captivity, but when I came to do the job, I just scraped my old bearings in and sold the new bearings for a large amount of cash.
          Andrew.
          Edited By Andrew Tinsley on 17/04/2021 14:57:16
          #540222
            Posted by Andrew Tinsley on 17/04/2021 14:56:13:
            I’m not being funny, Andrew … just genuinely curious to know how that works
            It’s easy enough to lower the bearing-cap a little; but what do you do about its width ?
            duncan webster 1
              @duncanwebster1
              A bit left field. but would one of the modern plastic bearing materials work? There is a full size loco running around with PTFE coupling rod bearings and by all accounts it is successful
              #540230
              Andrew Tinsley
                @andrewtinsley63637
                Hello Michael,
                I didn't have to skim my shaft, so it wasn't a problem. I did a friends lathe which did need a few thou skimmed. I finished up with a non contact line at the bearing joint, it wasn't more than a few degrees either side of the joint., I just left it at that and it has performed well over a good few years.
                I could have skimmed the top half of the bearings and made some improvement, but why bother when it all worked without trouble. No doubt the perfectionists will not like it, but then they would probably purchased the hardened mandrel and phosphor bronze bearings from Myford.
                Andrew.
                #540232
                  Thanks for that, Andrew
                  … my ‘fear’ was that the oil might drain away rather too quickly.
                  Not a problem for me anyway, as I have an ML7R … but it’s useful to learn from the experience of others.
                  Steviegtr
                    @steviegtr
                    Is there no companies out there that would white metal spray the old shells.
                    Steve.
                    #540241
                    Andrew Tinsley
                      @andrewtinsley63637
                      That would be good if it works. I know a little about metal spraying, but not too sure if white metal alloy would spray too well, because of its low melting point.
                      Anyone really knowledgeable about metal spraying?
                      Andrew.
                      P.S. I have in the distant past, cast white metal bearings for full size locos. (Scraping axle boxes is hard work when you have to put the box on and off the wheel journal) . It would be an easy job to remetal or simply add a layer of white metal onto ML7 bearings. I am not even sure that the ML7 bearings have a backing. Making new ones should be pretty straightforward.
                      #540246
                      V8Eng
                        @v8eng
                        I am not sure how far Noel has got with this  but it might be worth checking out the related thread here:-
                        ML7 Bearings
                        Sometimes Shafts and Bearings appear on eBay as well.
                        Edited By V8Eng on 17/04/2021 18:36:50
                        Edited By V8Eng on 17/04/2021 18:37:06
