MYFORD CHANGEWHEELS
MYFORD CHANGEWHEELS
Home › Forums › Beginners questions › MYFORD CHANGEWHEELS
  • #305172
    Andrew Tinsley
      @andrewtinsley63637
      I am looking for a 42 and a 48 change wheel for my ML10. I need them to cut some metric threads (The lathe is imperial). The usual suspects don't seem to have any, unless I need to go to Specsavers!
      Anyone any idea where I might look next?
      Andrew.
      #8765
      Andrew Tinsley
        @andrewtinsley63637
        #305174
        Bizibilder
          @bizibilder
          Have you tried Myford themselves?
          #305175
          John Haine
            @johnhaine32865
            Have PM'd you.
            #305176
            Dennis D
              @dennisd
              Saw some yesterday at the Guildford show , think it was on the Home and Workshop Machinery stand. Might be worth giving them a call Monday . They usually have a full page add at the back of MEW
              #305178
              Andrew Tinsley
                @andrewtinsley63637
                Bingo! Myford's have them, a bit pricey but can't complain! I looked up RDG as I assumed they were the same outfit as Myford, well they operate out of the same address. RDG didn't have them so I assumed that Myford would not.
                Apologies all, I really should have looked up Myford rather than RDG!
                Andrew.
                #305179
                Brian Wood
                  @brianwood45127
                  Hello Andrew,
                  ​You might not need them, I have calculated Myford gearings, some including a 63 T wheel that give very close results without having to buy 'exotics'
                  If you will tell us which pitches you need to cut I'll see what arrangements there are with standard wheels.
                  ​Regards
                  #305183
                  Hopper
                    @hopper
                    If you get a copy of Martin Cleeves' book "Screwcutting in the Lathe" it includes a chart of how to cut metric threads on an imperial Myford using the standard set of change wheels (20 through to 65 or 70 in steps of five). No need for 63T, 127T or other specials. He does it by using compound gearing and accuracy is in the range of within one thou in eight inches or so in most cases, ie well within limits for normal turned threads and probably more accurate than the mass produced lead screw Myford used! I've used Cleeve's chart for cutting metric threads on my old M-type numerous times with complete success.
                    Edited By Hopper on 02/07/2017 13:22:19
                    #305187
                    Roderick Jenkins
                      @roderickjenkins93242
                      Andrew,
                      Possibly this table is useful. Might be worth seeing whether a combination shown below will mesh on your machine. If the pitch you are after isn't here then I'm sure we can find suitable combination with your existing changewheels.
                      HTH,
                      Rod
                      #305219
                      Andrew Tinsley
                        @andrewtinsley63637
                        Brian, Hopper and Roderick, you are dead right in what you say! I am embarrassed, because I have Martin Cleeve's book and indeed Brian's excellent book, "Gearing of Lathes for Screwcutting", I can highly recommend both of them.
                        I have worked out how to get around the need for a 42 and 48 gear wheel, you gentlemen are right on the money! It really is pathetic to have a library that could have answered my query and simply not use it. No point in reading it for bedtime use and not use the info in practice! I am slowly coming off some potent medication and I can blame my lack of thinking on that (well I really hope that is the reason!) .
                        Thanks all for putting me right,
                        Andrew.
                        P.S. I actually enjoyed doing the calculations to get me as near as damn it the correct metric threads. A bit worrying , I thought I had left behind the need for maths.
                        #305230
                        Brian Wood
                          @brianwood45127
                          Hello Andrew,
                          ​It was generous of you to admit your failings I must say, but no harm has been done expect perhaps to your pride.
                          ​The fog of medication can do bad things to concentration and I for one hope you can put the whole episode behind you and forge ahead.
                          Good luck in the future
                          ​Brian
                          #305253
                          Andrew Tinsley
                            @andrewtinsley63637
                            Hello Brian,
                            Thanks for your words of encouragement. Large doses of morphine don't help with cognisance and I have made rather too many similar blunders, while under the influence. I have kept well away from machine tools, but hopefully I can safely get back to machining soon.
                            May I congratulate you on your book. It is full of useful information for many different lathes used by model engineers. The book itself is beautifully produced and must be one of the best presented model engineers book of all time. I heartily commend it to everyone on the forum
                            Andrew.
                            #305262
                            Hopper
                              @hopper
                              Good result! All the best with your metric endeavors. And thanks for the tip on the other book, I havent come across that one before. Must have a look!
                              #305392
                              Brian Oldford
                                @brianoldford70365
                                Save yourself the faff and install the application that's here.
