Myford bearing taper
Home › Forums › General Questions › Myford bearing taper
Viewing 25 posts - 1 through 25 (of 48 total)
  • #23466
        I'm planning to make an accurate spindle running in plain bearings. I want to use a small version of the Myford -style tapered front bearing. This seems to be the best and simplest way to make a plain bearing adjustable for wear/play without using a split bearing. Can anyone tell me what the Myford taper angle is?
        Brian Wood
          @brianwood45127
          Hello Neil,
          2 degrees and 25 minutes inclusive. Source Tubal Cain Model Engineer's Handbook 3rd Edition
          #161046
          Emgee
            @emgee
            Hi Brian
            Viewing the picture of a spindle at CotswoldsPhil album
            Reply To: Finding a penknife
            makes me think itis greater than 2deg25min taper.
            Emgee
            Edited By Emgee on 18/08/2014 10:13:51
            Edited By Emgee on 18/08/2014 10:15:59
            #161048
            Brian Wood
              @brianwood45127
              Hello Emgee,
              I was only quoting what the great man had published, but I agree with you; checking Morse taper standards shows the half angle for say 2MT is not far away from half that value..
              Maybe the figure should have been for the half angle, running a taper as fine as MT would grab and lock up in moments.
              That would make the bearing taper Neil needs to be 4 degrees and 50 minutes, more in the category of self releasing too. Well spotted!
              Regards Brian
              #161049
              CotswoldsPhil
                @cotswoldsphil
                Hi,
                That's my picture uploaded just last week – glad to be of service. If the spindle was still on the bench I could check it for you. Just with a protractor over the picture says it's more like 20' inc.
                Phil H
                #161051
                Brian Wood
                  @brianwood45127
                  Hello Phil,
                  Tubal Cain's book could have a typo then, that would make the angle 20 degrees 25 minutes—it makes a lot more sense at that. I have in the past taken my spindle out and from memory it is as you say, a much steeper taper.
                  Sorry Neil, it's all looking like a bugger's muddle now, maybe someone else can weigh in with a correct answer.
                  Regards Brian
                  #161052
                    I forgot it was on the mandrel nose drawing!
                    The great man was pretty good at getting confused about half-angles.
                    I spent a good while trying to check out the formula on page 3.1, (3rd edition), where x should be radius not diameter and the formula will then give the correct single-sided taper, not taper on diameter.
                    He doesn't seem to have registered that 2 * tan (theta/2) is not the same as TAN (theta), although the error at small angles is… small.
                    I was thinking about an included angle of about 5 degrees or 1 in 10. That would make it easy to adjust running clearance – a 20tpi thread for the thrust bearing adjustment would give 5 thou adjustment per turn. Assuming a precision run fit of 0.001", that would be 10 thou away from locking up.
                    Problem is that bigger angles are more critical for the adjustment.
                    More thought needed!
                    This is for a new headstock for a Super Adept by the way, aim is to make it a BGSC lathe. The existing spindle has 2 thou of wear and the front bearing has been cracked during an attempt to adjust it out. The bearing centreline drops by about 1/8" at the tailstock over the full length of the bed.
                    Other alternatives are small roller bearings or magneto bearings, but these all seem to have excessive OD's of about 1 1/4" to pass a 1/2" spindle, which is needed to accommodate an 0MT taper.
                      Posted by Neil Wyatt on 18/08/2014 10:51:15:
                      Now there IS a surprise !!
                      John Stevenson 1
                        @johnstevenson1
                        Well if I had know it was for a sooper non-adaptable lathe I wouldn't have bothered reading this post…………yawn.
                        #161062
                          I knew there'd be trouble if he found out!
                          It's alovely set of castings from which to make a small lathe!
                            Posted by Neil Wyatt on 18/08/2014 13:09:51:
                            I look forward to seeing what can be done.
                            Although the single taper is perfectly viable, you might like to consider the "double cone" arrangement that was commonly used on Geneva Pattern, and early Webster Whitcomb lathes. [see here for a couple of good cross-sectional drawings]
                            These are usually hardened steel on hardened steel, but I'm sure that other material combinations would work too.
                            The idea is that the steep taper takes most of the thrust, and allows the other taper to be very shallow without risk of it sticking.
                            Edited By Michael Gilligan on 18/08/2014 13:52:20
                            #161070
                              I know the double taper arrangement. My congratulations to anyone who can turn a mating double-taper bush and spindle to the required accuracy. I won't be joining them!
                              Robbo
                                @robbo
                                Neil,
                                I can't do spot-on measurements today, as have got the tremors – the joys of old age!
                                But a measure with a vernier on an old S7 spindle shows approx. a 10.3mm difference in diameters end to end of the taper, over an axial distance of 57mm.
                                You can probably work out the probable taper from that – sines, cosines, tangents etc are just something listed in the back of my book of logarithms to me.
                                Phil have corrected all the typos – and there were many.
                                #161117
                                  Thanks Phil,
                                  That works out at about 1 in 6, or 1 in 12 on each side. I was looking at 1:10 but this made the front of the bearing a little thin for comfort, so 1:12 it will be.
                                    One inch in the foot is a very Imperial sort of Taper
                                    Yes … It seems very likely that Myford would have used it.
                                    P.S. Neil … are you retaining a 3/8" spindle diameter?
                                    or is the rear bearing worn also?
                                    #161143
                                    Chris Trice
                                      @christrice43267
                                      I’ve got a spare Super 7 spindle here and just carefully eyeballing it, the taper I get is 12.5 degrees inclusive or 6.25 from the axis. If you’re making your own spindle and bearing, I don’t suppose it’s critical.
                                      #161144
                                      Chris Trice
                                        @christrice43267
                                        That figure was got by transferring straight lines onto a piece of paper and then measuring it with a protractor.
                                        #161145
                                        Chris Trice
                                          @christrice43267
                                          Tubal must’ve missed a “1” off the start of his figure.
                                          #161147
                                            Darn it!
                                            I seem to have lost a long explanation of how I intent to go about constructing the headstock.
                                            I'll do some drawings, maybe try a 3D model…
                                            Chris Trice
                                              @christrice43267
                                              Based on your first post Neil, you appreciate that any thrust towards the headstock is actually taken by the angular contact ball races? I hope I’m not insulting anyone’s intelligence but the comment about Morse taper angles doesn’t make any difference because the taper plays no part in resisting movement along the bed. It’s purely there so the running clearance can be controlled.
                                              #161216
                                              Brian Wood
                                                @brianwood45127
                                                Hello Chris,
                                                You are of course absolutely right, with tapers as fine as Morse it would only take microns of lateral movement for the faces between mandrel and bearing to run the risk of grabbing and seizing up. A steeper taper, as now turns out to be nearer the truth, resists that and gives much better feedback as the clearance is reduced.
                                                I was trying to equate a quoted angle with other examples of taper angle for reference.
                                                Regards Brian
                                                Edited By Brian Wood on 20/08/2014 09:23:29
                                                #161237
                                                Chris Trice
                                                  @christrice43267
                                                  Absolutely. A taper the equivalent of a Morse would need very careful adjustment. Binding may not be quite such a problem with steel against bronze but the point is well made.
                                                  #161239
                                                    Hi Chris,
                                                    That's exactly my understanding. I find it hard to understand why Myford never used or moved to taper rollers, which were well understood by 1947, but the plain taper and even a plain thrust washer on bronze bush at the tail is ideal for my needs with such a small spindle,
                                                    Nigel McBurney 1
                                                      @nigelmcburney1
                                                      When Myford designed the S/7 it was in a time after the war had just finished and the UK was involved in the Korean war and priority was for aircraft and armanents ,lots of industries suffered from this having to modify their products due to non availability of things like alloy steels,chromium plating etc and suitable bearings may not have been available,also there is a lot to be said for plain tapered bearings they do help achieve very good surface finishes ,German instrument lathes used both tapered bronze bearings and hardened steel bearings. If Myford had selected a tapered roller bearing then, I expect that everyone would be now moaning that the type of bearing selected was now obsolete ,at least a bronze bush can be machined up to suit,
                                                      My old company circa 1985 purchased a lathe for diamond turning fine finishes and that had plain white metal bearings .
