Myford 3 phase to single
Home › Forums › Beginners questions › Myford 3 phase to single
  • #99220
    chris j
      @chrisj
      I'm looking at a Myford 254 Plus that requires a 3 phase supply and I don't have one sadly. I believe it is currently fitted with a 2hp – 3 phase motor.
      What would the panel suggest I do, inverter or new motor ?
      Anyone got an idea of cost
      #6353
      chris j
        @chrisj
        #99224
        blowlamp
          @blowlamp
          Inverter, without a doubt.
          Martin.
          #99226
          Sub Mandrel
            @submandrel
            From what I can see motor cost ~= inverter costs. If its a nice motor, get the inverter and all the advantages it brings rather than 'downgrade' to single phase.
            _Paul_
              @_paul_
              Another option might be to run the 3 phase motor using a couple of capacitors, one to start one to run should give you about 60-80% of its full power.
              Or if youre feeling really adventurous you could follow what I and many others have done and build a Phase convertor either Static or Rotary.
              There are some good books in the Workshop Practice series on the subject.
              Paul
              #99240
              chris j
                @chrisj
                Paul
                Thanks for the relpy but I can't make more things !!
                My wife asked me today, so what are you making.
                I told her I was making little tools to help me make other things later.
                I got one of those looks sad
