My Ford Super 7 Countershaft Balance
Home › Forums › Manual machine tools › My Ford Super 7 Countershaft Balance
  • #641909
    Andrew Knowles 2
      @andrewknowles2
      Has anybody had any issues with the balance of the countershaft/clutch assembly
      I have no vibration from the motor on its own (3phase Newton Tesla) but when I put the belt to the countershaft on but with the belt to the spindle off there is vibration
      The large pulley on the clutch appears to be out of balance. Ie place it in one position and it will move round on its own always stopping in the same spot
      The problem was much improved when fitting the 3phase motor but the vibration is still there
      Thanks for any help or ideas on how to balance it
      #14812
      Andrew Knowles 2
        @andrewknowles2
        #641910
          So-called ‘Static Balance’ is relatively simple to check and adjust
          Mount the pulley on a plain shaft and set it on a pair of parallel knife-edges
          Edit: __ this illustrates the concept, on a smaller scale
          https://clocksavant.com/blogs/news/watch-timing-and-accuracy-static-vs-dynamic-poising-balance-wheel-poising
          When it settles: Remove material from the heavy spot [or add weight at the top]
          Repeat the process until it settles in a different orientation every time you disturb it.
          Dynamic Balance [like the tyre shop does] is, of course, more difficult.
          Edited By Michael Gilligan on 19/04/2023 17:21:28
          #641913
          noel shelley
            @noelshelley55608
            2 clutches were used on the S7 the early moped front brake and the later cone clutch. I would check that the clutch unit has not gone out of balance before trying to balance the pulley. Noel.
            #641915
            ega
              @ega
              Is it possible, please, to correct the thread title so that it can more easily be found in future?
              #641916
              bernard towers
                @bernardtowers37738
                If the vibration is there before engaging the clutch it should mean that its the clutch driven pulley.I have just looked at mine and there are balance drillings on the back which you can see with a mirror and torch.
                #641927
                Zan
                  @zan
                  When I got my new s7 (1982) I too had bad vibration. It came from the primary drive belt whipping. A call to myford and it seems this was a common problem which they couldn’t test at the factory cos in those days the lathe came with no motor, chuck or much else! It was completely cured when they supplied a brammer line belt which I used until fitting a vdf and 3 phase 25 years ago, when the motor drive pulley diameter was changed to stop excessive motor speed and vdf frequency with high speed turning
                  #642000
                  bernard towers
                    @bernardtowers37738
                    Ive never had any vibration problems with my S7 in single phase mode or 3 phase so it could be belt induced.
                    #642120
                    Howard Lewis
                      @howardlewis46836
                      Some v belts are fatter atb the join, and this can produce vivratiob because of the join riding furtherv out in the V .
                      Maybe a change to a better belt might cure the problem?
