More good machining videos
Home › Forums › Manual machine tools › More good machining videos
Viewing 15 posts - 1 through 15 (of 15 total)
  • #129770
    Roger Williams 2
      @rogerwilliams2
      Hello, just found these good videos on U tube, coming under OXTOOLCO, a chap named Tom Lipton I think. Theres a particularly good one, over an hour long, on buying a lathe. Interestingly, in one of the videos making pins, I couldnt help but notice on the rather nice lathe he is using, what looks like about a 10 inch, 6 jaw SC chuck, with Pratt Burnerd , made in England, written on it !!. Anyway, nice bloke, and worth watching I think.Cheers.
      PS, Im hoping JS can put a link for the videos, I havent a clue Im afraid ! wink
      #12191
      Roger Williams 2
        @rogerwilliams2
        #129772
        Brian Still
          @brianstill44962
          Hi
          This is the link I believe you are referring to. **LINK**
          Thanks for the pointer
          #129773
            Or better still
            #129780
            Roger Williams 2
              @rogerwilliams2
              Thanks both for that. Another of his many videos is titled " Toms 2 cents worth on Vice Tramming ", brilliant. Tom makes a nice reference to John of Doubleboost fame with regards to his idea of Ikea lamps in the video about tools. Cheers.
              #130015
              M0BND
                @m0bnd
                I can't think why, but when he skimmed the face true, why didn't he turn a register diameter the same size of the existing bore in the part? This would have saved a lot of time when clamping the part to the plate later?
                Andy.
                #130047
                OuBallie
                  @ouballie
                  Andy,
                  Didn't think of that solution – DUH!
                  I was, however, shouting at him to put either a short thread or jacking screw in the centre hole of that disk, to be able to free it.
                  As soon as he resorted to using a hammer to get it to seat, I saw problems, but he did eventually solve it.
                  Wood for trees scenario.
                  Is that his private workshop, or very understanding employers/friends?
                  Geoff – A day to chill out.
                  #130063
                  Ian P
                    @ianp
                    The title of this thread is 'More good machining videos'. Well I watched most of that one but I would nor describe it as good. I have no authority or right to criticise as I could not do better myself) but I found it repetitive and mostly boring.
                    From the information I could glean by looking at the part, his lathe and chuck etc I am sure the hole could have been opened up in 15 minutes total. He could have removed the chuck and fitted the faceplate and saved himself a lot of time.
                    Did he say why a 1/8" thick part of folded sheet needed the bore to be at such a precision right angle that his aluminium plate needed skimming? Earlier he said the bore was to 3.75" 'plus a bit' so that does not sound great accuracy was required.
                    Ian P
                    #130084
                    Anonymous
                      Now this is real hard man machining:
                      You wouldn't want to get in the way of that swarf!
                      #130139
                      Roger Williams 2
                        @rogerwilliams2
                        Hello all,, Oh well, I will leave out the good bit next time. Only trying to help !.sad
                        #130143
                        Anonymous
                          Roger: I wouldn't worry about, everybody will have their own view on what's good and bad.
                          #130150
                          Speedy Builder5
                            @speedybuilder5
                            Does this guy make a living?? I went back to the workshop to watch the paint drying !!
                            #130151
                            Speedy Builder5
                              @speedybuilder5
                              Now Andrew's link – That's different.
                              #132227
                              Mike Armitage
                                @mikearmitage
                                I spent hours catching up on Keith Fenner's site on U Tube. Turn Wright Machine Works. He's a good all rounder machinist. **LINK**
                                #132237
                                Pete
                                  @pete41194
                                  He's posted a very clever way to properly tram in a mill vise as Roger has already mentioned. That was a brand new and very welcome idea to me. So many thanks for the heads up. Yes the first video was repetitive and probably boring, but there was quite a bit of useful info in it. Much better than a lot of videos that aren't boring, yet the information can be anything but correct. Just because it's on Youtube it obviously doesn't mean it's automatically 100% right.
