ML7 cross and top slide threads?
Home › Forums › Beginners questions › ML7 cross and top slide threads?
  • #303178
    Andrew Tinsley
      @andrewtinsley63637
      I am just too hot to venture into my shed, which must be like an oven. Otherwise I would measure up the required thread!
      Google and my library don't seem to help either. I am after the imperial threads, definitely acme but what pitch and diameter?
      I shall probably need to buy or make some replacements, when I am able to get mobile again after my latest attack of sciatica!
      Thanks everyone,
      Andrew.
      #8755
      Andrew Tinsley
        @andrewtinsley63637
        #303183
        Steven Vine
          @stevenvine79904
          Well, I would go into my hot workshop, run around, and measure up for you, but I'm glued to an armchair at the moment!!smiley
          Steve
          Edited By Steven Vine on 19/06/2017 15:02:53
          #303186
          Gordon A
            @gordona
            Hi Andrew,
            3/8 x 10 TPI for both (imperial)
            Gordon.
            #303188
            Robbo
              @robbo
              Imperial 3/8" x 10 tpi, see **LINK**
              #303189
              Howard Lewis
                @howardlewis46836
                But remember that they will be Left Hand, possibly ACME or square thread form, so that the slide advances when the handle is turned clockwise.
                #303195
                Rick Kirkland 1
                  @rickkirkland1
                  I hope to God they’re NOT left hand. Otherwise they would work in reverse !!!!
                  And there’s no ‘possible’ about it. They are Acme form.
                  Edited By Rick Kirkland 1 on 19/06/2017 15:25:10
                  #303203
                  Howard Lewis
                    @howardlewis46836
                    Rick, If the thread were right hand, as the handle is turned clockwise, you would withdraw the tool from the work.
                    (I have made a new nut for a Raglan Cross Slide, so know that the thread is left hand.
                    But we do agree over the thread form!
                    #303214
                    Rick Kirkland 1
                      @rickkirkland1
                      ML7 top and cross slide feed screws are RIGHT HAND ! The nut is stationary and the RIGHT HAND feed screw pulls toward the nut moving the slide forward. If it was Left hand it would back the slide off when rotated clockwise. I’ve machined new screws and nuts for six ML7 lathes in recent years. The LEADSCREW is Left hand, were it not clockwise rotation would drive the carriage toward the tailstock, not the headstock. Have a think about it.
                      Edited By Rick Kirkland 1 on 19/06/2017 16:11:26
                      #303222
                      Rick Kirkland 1
                        @rickkirkland1
                        I will add this to assist the thought process. ML7 top and cross feed screws ride with the slide. A left hand thread needs to be used where the slide feed nut rides with the slide. ML7 ‘s have a nut captive on the carriage and the topslide base. Therefore, a Right hand thread needs to be used.
                        #303231
                          Very well explained, Rick yes
                          Rick Kirkland 1
                            @rickkirkland1
                            Thank you Michael G. I do come in handy sometimes. Thankfully.
                            #303609
                            Howard Lewis
                              @howardlewis46836
                              Quite right Rik, memory failure, (The ML7 went some 14 years ago. But you have reawakened memories of fitting a new nut to the Cross slide)
                              Apologies for the confusion with moving nut machines!
