Mk1 Colchester student clutch
Home › Forums › Help and Assistance! (Offered or Wanted) › Mk1 Colchester student clutch
  • #33671
    old Al
      @oldal
      #494704
      old Al
        @oldal
        Hi.
        I have been turning some 15"dia stainless plate and the lathe keeps slowing down and stopping.
        My immediate thought was that the motor was overheating, not so. my next thoughts were the clutch. I know the mk 1 1/2 has a working clutch, but where that is (the top belt pulley area) is getting hot.
        Is their any friction material stuffed into that area that might be giving me grief
        Thanks
        Alan
        #494716
        Ian Parkin
          @ianparkin39383
          You can have a clutch fitted
          does your motor run then when you lift the start handle the spindle starts?
          or when you lift the handle does the motor start? And the spindle?
          if you don’t have a clutch you should have a brake in the pulley area which could be giving problems
          but first I’d look at your drive belt/s
          #494772
          Phil Whitley
            @philwhitley94135
            The top belt pulley has the brake mechanism inside it, sounds like it is binding, the clutch, if fitted, is inside the headstock, from what you describe, the brake needs adjusting, when you push the handle down to stop the lathe, if you keep pushing it applies the brake.
            #494954
            Ian Parkin
              @ianparkin39383
              The clutch if fitted is outboard of the pulleys away from the headstock
              dsc02094 (medium).jpgYou can see it out of focus behind my home made brake…if you have a clutch you cant have a brake usually
