Minnie Traction – Winding Drum Cable
Home › Forums › Beginners questions › Minnie Traction – Winding Drum Cable
  • #349493
    Malcolm Farrant
      @malcolmfarrant93389
      According to L C Mason Reeves used to keep suitable cable for the Minnie, but they do not now.
      Any suggestions as to what cable to get.
      It seems, according to Mason, I need about 7 yards. Is that correct.
      Many thanks to all
      Malcolm Farrant
      #9158
      Malcolm Farrant
        #349494
        roy entwistle
          @royentwistle24699
          Any of the clock material companies. A long case clock uses 21 feet. A Vienna regulator will use less
          Possibly model aircraft shops. Tethered flight etc
          Roy
          #349495
            I've used these people a few times. The 7×7 stainless will wrap around the drum OK.
            They also do 1.5mm thimbles if you don't fancy making your own.
            Edited By JasonB on 09/04/2018 09:33:53
            #349585
            Malcolm Farrant
              Thank you both for your suggestions.
              Jason, I have had a look at the web site there is under the 7×7 very many thicknesses. Would you suggest the 1mm or thinner.
              Equally not sure if they sell by the meter or by spacific drum lengths.
              Yeas the 1.5mm thimbles might be a very good idea.
              Very best and thank you both again
              Malcolm
              #349588
                Google "stainless steel trace wire" and you may find something suitable.
                #349598
                  Just measured my Reeves supplied cable at 1.48mm so the 1.5mm from tecni-cable will be fine. Quantities in the box are for 1m @ 41p per mtr. for the 7×7 strand or 76p per mtr for the even more flexible 7×19 strand
                  #349739
                  duncan webster 1
                    @duncanwebster1
                    Bicycle brake or gear selector cable? The gear selector stuff is thinner. My locol bike shop sells it by the yard
                    #349767
                    Bazyle
                      @bazyle
                      It is a 1/12 scale model so I think 1.5mm would scale to a sensible size but go for the finer strand version as a full size cable with only 7 strands wold look a little clunky.
                      #349778
                        Bazyle, they don't do a 7 strand, the 7×7 has 49 strands and the 7×19 has 133 strands. They also do a 19 strand but that is not very flexible which is why I did no suggest that because it will be like a spring wound around the 3" dia drum.
                        #349783
                        Raymond Griffin
                          @raymondgriffin40985
                          I recently purchased a length of cable for my I” Minnie from Blackgates Engineering. It is 1.5mm in diameter, very supple and will do nicely. I can’t remember the cost, but certainly not worth haggling about.
                          Ray
                          #349788
                            Posted by JasonB on 11/04/2018 07:25:13:
                            My thinking behind trace wire, it is very flexible. Full size cables would have dozens and dozens of strands.
                            #349811
                            Malcolm Farrant
                              Yet again very, very many thanks to everyobne for your input.
                              I have gone with Jason's suggestion and am using Techni-Cable,. In conversation with them I was impressed by how very helphul they were. As suggested by Jason I have also bought the thimple from them.
                              As a passing comment I am just so impressed with how helpful everyone is. Alas I seem to have a steady stream of question and problems and evey time i seek help i get an instant helpful response.
                              A big thank you best wishes
                              Malcolm
                              #349825
                              duncan webster 1
                                @duncanwebster1
                                Malcolm, I've sent you a PM
