Minnie Traction – Hornplate
Home › Forums › Beginners questions › Minnie Traction – Hornplate
  • #335611
    Malcolm Farrant
      @malcolmfarrant93389
      More confusion today.
      The drawings show a drilling template layout on page 30 of the book. This show thw lowest row of holes to be 1" from the base line,. but the plan s (which is drawn to scale gives no meaurement as to where the lowest line of the nine holes are, but in measuring it appears they are 5/8" to the center from the base line.
      Which is correct or am I mis-reading something ? Or does it not matter if you follow the template drawing or the Plan.
      In anticipation …yet again
      Best wishes
      Malcolm Farrant
      #9035
      Malcolm Farrant
        #335627
          The template is for marking out the stay positions on the boiler. The hornplates do not come down to the bottom of the boiler hence the holes are a different height.
          Look at last paragraph page 35 for how to position the templat eon the hornplates so you get the holes where they are required
