Posted by JOHN BURNELL 1 on 08/09/2017 16:13:18:
… i was thinking of grinding some 5mm hss bar stock i got free, but im new to this and was thinking of buying some ready made tools the carbide inserts not the cemented type as i beleive these are not good, then later on having a go at grinding my own, just after some opinions .
regards john
That's what I did. As a rank beginner I found grinding HSS from scratch too difficult. Carbide inserts are initially expensive, but you don't have to sharpen them. That eliminates a possible source of learner error. It's easier to blunt HSS by overheating it than carbide and a beginner may not realise when HSS needs resharpening. Also, if you happen to break an insert, you can replace it without having to reset the tool height, that can save lots of time.
For me the cemented carbide type are neither fish nor fowl. Their advantage is cheapness compared with inserts and the ability to work hotter and faster than HSS. Apart from that, they have the disadvantages of both HSS (has to be reground) and Carbide (may crack). In practice I switch happily between HSS and indexed tips and never use the cemented set I own.
Many people swear by HSS, others prefer carbide. I mostly use carbide inserts, but there are plenty of times when I think HSS is 'better'. A great deal depends on what you're using the lathe for and what sort of lathe it is. Carbide doesn't give it's best on a slow lathe doing small diameter work. Your Cowell's is quite quick, so I think you'll be happy with inserts. HSS will be useful when you want to take very fine cuts with a sharp tool, and it sometimes produces a better finish.
After you've used the lathe on your metals of interest you will soon develop a much better feel for what suits you. I don't think you will regret starting with carbide inserts; they'll occasionally be useful even if you end up a committed HSS fan. Don't be too intimidated by theoretical complexities: the best way to find out is to get on with it and use the lathe. Use known metal rather than scrap. A lot of scrap (and some DIY store metal) is truly horrible – don't blame the lathe or yourself if odd lumps of metal behave badly! Getting the very best from a lathe will take time to learn, but they are quite forgiving while you learn the ropes.
