Mill vise and rotary table
Home › Forums › Beginners questions › Mill vise and rotary table
  • #559761
    Dalboy
      @dalboy
      I have seen and heard of people fixing both on the milling table. will the effect the wear when for example the vise is used a lot more than the rotary table, meaning that the weight of the later is overhanging the end.
      I hope my explanation is clear
      #10938
      Dalboy
        @dalboy
        #559762
        Anonymous
          I find having multiple items on the table never seems practical, something always seems to be in the way. So I generally fit just the item I need to use; my mill table is 48" long.
          #559765
            I'm the same as Andrew and generally just have the one item on the table. On the odd occasion when I just want to quickly use the 5C spin indexer I may leave the vice in place but it can get in the way of inserting the work.
            Mine is not as long as hissad
            #559773
              Like Andrew I find having both on the table wastes so much space, it's rarely worth doing. The Rotary table is usually the wrong way round too; horizontal when I want vertical and vice versa.
              So, unless I've planned a work-sequence specifically to use both, which is unusual, the rotary table is normally kept in it's box. As always much depends on what you do in your workshop. I suppose 75% of my milling is done in a vice, 10% rotary table, and the rest on a angle plate or clamped direct to the table.
              Apart from keeping the ways clean and gently oiled, I don't worry about wear except when grinding or machining cast-iron. The machine only has to last longer than I do!
              Nicholas Farr
                @nicholasfarr14254
                Hi Derek, I'm the same, normally only have one thing on the table. My Major mill is about 60% the length of Andrew's one and by the time I get anything on my mini mill, there is absolutely no room for anything else.
                Regards Nick.
                #559784
                Tony Pratt 1
                  @tonypratt1
                  I just keep one bit of kit on the table, as already stated the 2nd item will always be in the wrong place.
                  Tony
                  #559786
                  Colin Heseltine
                    @colinheseltine48622
                    Just one 99% of the time. I have Bridgeport sized machine and the 6" Bison vice is rather large and fitted in centre of table. I had a job the other week which required the large 10" rotary table. Left the vice on, centered the rotary table under quill and mounted the job. Only to find about 10mm short on X axis movement. Removed every thing, took vice of and put RT in middle of table. Because of the weight of the vice, rotary table and Bison indexer I would rather have them in middle of table than overhanging the knee and risk flexing the table.
                    Colin
                    #559789
                    Anonymous
                      Another consideration is that having a heavy item at one end of the table makes it much harder work to wind the handles, in all axes.
                      #559794
                      Clive Foster
                        @clivefoster55965
                        Not forgetting the risk of chomping the one not in use when moving the table to clear the cutter from the work in progress to measure it.
                        #559795
                        Howard Lewis
                          @howardlewis46836
                          I rarely have two devices on the table at the same time (Rotary Table, or tilting vice ) because of the risk work in one obstructing, or being obstructed by the other.
                          So, most of the time the K4 vice sits centrally on the table, occasionally being displaced by the Rotary table of the "Infinite" vice.
                          #559796
                          Martin Kyte
                            @martinkyte99762
                            Not a rotary table and a vise but I do have space to mount my George Thomas versatile Dividing head at the end of the table for quick use without removing the milling vise. It has a Tee slot adaptor plate/raising block which keys it to the Tee slots and is quick to mount and demount. Great for swift cross drilling or milling squares without removing the work from the chuck and then back to the lathe.
                            regards Martin
                            #559799
                            Brian Baker 2
                              @brianbaker2
                              Greetings, I to have a small dividing head mounted on the right hand end of the Myford VM-F mill, very useful.
                              Quick to remove, and a fixed tongue tenon makes it easy to replace.
                              Used exactly as Martin describes above, very useful.
                              Regards Brian
                              #559808
                              Ron Laden
                                @ronladen17547
                                My SX2P doesn't have the largest of tables so I only mount one item on the table and my vice lives on the table most of the time. Mounting both the vice and rotary table at the same time would put them both at the ends of the table which depending on the job could mean running out of travel in one direction.
                                #559811
                                Dalboy
                                  @dalboy
                                  Thank you all for your input. So really advised against this so I will mount the vise centrally and change over as and when needed.
                                  #559958
                                  old mart
                                    @oldmart
                                    If your vise is no bigger than 4", 100mm, then it is not so heavy to move and it can be removed in seconds. A 6" rotary table with a chuck on it is getting close to my limits, but does get in the way if left on the mill, and I am one of the lucky people to be able to choose which of the two mills sitting side by side at the museum to use for a particular job. Today I wanted to square off a 3 inch wide workpiece using the Y axis, and the Tom Senior was not up to it even trying different table slot positions for the 100mm Bison vise. I just moved to the drill mill and the job was easy. With hindsight, I could have removed the key from the vise and mounted it lengthways on the TS bed.
                                    Edited By old mart on 26/08/2021 20:52:22
                                    #560065
                                    Howard Lewis
                                      @howardlewis46836
                                      Unless the vice is keyed to the table, replacing it will bring the problems of realigning it.
                                      To avoid spending ages tapping (knocking ) it and winding to and fro with a clock, it will be worth making up some form of alignment jig.
                                      My goalpost fixture may cause mirth, but it sets the vice within 0.001" in less than 5 minutes, instead of 20 minutes of clocking and frustration.
                                      (As an Apprentice spent many unhappy times trying get a 6 or 8 inch Abwood vice that close! )
                                      #560069
                                        The supplied keys on my ARC one set it to within 0.001" in 5 seconds rather than 5mins. The K4 does not have keys but less than 60 secs of tapping until the dti runs true is what it usually takes me, less if I use the power feed rather than hand winding..
                                        #560101
                                        Ron Laden
                                          @ronladen17547
                                          My vice keys get the vice within 0.002" to 0.003" I always clock the vice and it only takes a couple of minutes to get it pretty much spot on, under 0.001".
