Mill Tramming Query
Mill Tramming Query
Home › Forums › Beginners questions › Mill Tramming Query
  • #101064
    ChrisH
      @chrish
      I have read that a milling machine should be trammed before each project and even before starting work each day.
      What I do not understand is why this becomes necessary. Assuming only the one person ever uses a milling machine, and that it is not abused, why once the mill has been trammed to an acceptable degree of trueness should it go out of true?
      If a mill is of robust and solid construction what moves to send it out? I am thinking heavy vertical round column mill here, with solid base securely fastened down with four strong bolts.
      Would be grateful for illumination on this please.
      ChrisH
      #6389
      ChrisH
        @chrish
        #101065
        Ian P
          @ianp
          Well it would be good practice to check alignment daily but you would never have time to make anything.
          I think I would call tramming a mill 'work' so be hard to do before you start work!
          Seriously, I think what you read fall into the same category as, (for example)
          Checking Tyre pressures and engine oil level, screenwasher fluid before 'every' car journey!
          Ian P
          #101067
          David Clark 13
            @davidclark13
            Hi CrisH
            In industry we never trammed for the sake of it.
            Normally you would notice if a mill was not cutting square.
            Tramming was usually down after roughing down a job with a tipped cutter where you were taking heavy cuts and when you had tilted the head.
            Tramming does not take very long anyway, 10 minutes at most.
            regards David
            #101068
              A lot will depend on if you have a fixed head or one that can tilt side to side. I trammed my X3 when I got it by shimming the column to the base and have not touched it again in 5years.
              A tilt head mill even a bridgeport can go out of tram a lot quicker, take too heavy a cut or have some sort of snatch or jam up particularly on the smaller machines and things can move. On a machine like this its best to check before you do any majorly critical parts at least that way you get some work done rather than spending all day tweaking the last 0.00001"
              J
              #101078
              ChrisH
                @chrish
                I can see that with a head that tilts a heavy cut may move it out of true but for mills with fixed heads (that cannot tilt or swivel) then I still can't see what can put it out of true, unless it is the column that bends, but is that likely? I would have thought not, to bend it would need a cut so heavy that probably something else would shout first, like belt slip, or the motor stalling, but stand to be corrected!
                I agree that the advice to tram everyday falls into the same category as checking the oil etc each day on a car (Ian), you just don't do it, and reassured that industry never trammed for the sake of it (David), and that Jason has not touched his X3 in five years during which I hazard a guess that it would have had far more work than mine will have in the same time – all rather reassuring really!
                Chris
                #101079
                Ian P
                  @ianp
                  Doesn't the fact that heavy cuts or a snatch can disturb the settings of a milling machine indicate poor machine design or construction?
                  My Emco mill has a tilting head, no matter how tight I clamp the bolts I know it will move if I take heavy cuts, I'm referring to cuts that are well within the capability limit of every other part of the machine.
                  I am sure that at the design stage the head clamping arrangement could have been done better. As it is I have to be very careful using the machine as tramming (the head) can take an hour (Its a trial and error process as there is no fine adjustment other than changing the size of hammer!)
                  Ian P
                  #101080
                  Ian P
                    @ianp
                    Posted by David Clark 1 on 17/10/2012 09:47:58:
                    regards David
                    It would be too late if you noticed it after you had ruined a job that had had a lot of time invested in it!
                    Ian P
                    #101083
                    Andyf
                      @andyf
                      My old Dore Westbury has a round column. Tramming on the X axis is easy. because the head can be tilted, but tramming on Y involves shims.
                      If precision is essential, I check the tram. I'm not sure if the column is dead straight, so while it might be perfectly trammed at one height, that might not be true when the height is changed.
                      If shimming is needed, there's a nice way of finding what thickness is need on page 6 of this PDF.
                      Andy
                      #101084
                      KWIL
                        @kwil
                        A quick way of "checking" the alignment is to take a cut on a flat metal sample with a known sharp cutter and observe on the second clear pass how the cut is, leading edge only, trailing edge as well or heaven forbid, trailing edge only. Both axes. If clean cutting OK, if not, you have some idea as to the extent of "out of tram". Bear in mind that an out of tram head cuts a curved hollow along the direction of movement. Similarly if you cut a parallel 2nd pass then you can feel/see the "step" if you are out of tram.
                        #101086
                        David Clark 13
                          @davidclark13
                          Hi Bog Standard2
                          How about an article for MEW?
                          regards David
                          #101090
                          chris stephens
                            @chrisstephens63393
                            Hi DC1,
                            Remember the fun and games the last time Bog's words were in your magazine? His words and deeds but someone else's name appeared as the author, with the true author's permission, which upset a few people who knew who had written it.
                            christephens
                            EDIT. I do hope you can persuade John to write for you, his words of true wisdom are sadly missing laterly.
                            Edited By chris stephens on 17/10/2012 12:53:17
                            #101099
                            Nobby
                              @nobby
                              Hi Guys
                              At work we only checked alignment /tramming if we had tilted the head for putiing angle dowels etc.
                              Nobby
                              #101114
                              David Clark 13
                                @davidclark13
                                Hi Bogstandard2
                                I thought it deserved to be more widely shown. Not all Model Engineers' Workshop readers have access to the internet.
                                You copuld always donate fees to REMAP.
                                regards David
                                #101115
                                David Clark 13
                                  @davidclark13
                                  Hi There
                                  Was that the marcher engine rebuild?
                                  I had no idea it was written by someone else.
                                  regards David
                                  #101205
                                  David Clark 13
                                    @davidclark13
                                    I am sorry about this John
                                    He said he had permission.
                                    Not sure what I can do about it now.
                                    regards David
                                    #101206
                                    David Clark 13
                                      @davidclark13
                                      Emails as received.
                                      Regards David
                                      David,
                                      Thanks for your e-mail I have transfered all pics to CD with a Word doc which you can edit as you please .in the post to you Tues.
                                      Extra notes
                                      the engine size is 7/16 twin by 7/16 bore and stroke.
                                      The engineeer who did the refurb is John ******, John is not in the best of health at the present, and his wife is very ill.
                                      But he is quite happy for you to use for your publication,
                                      Regards Roy
                                      Hi Roy
                                      Who should I be paying?
                                      regards David
                                      Hi David.,
                                      Its OK to send payment to me, its been agreed,
                                      Roy
                                      #101267
                                      ChrisH
                                        @chrish
                                        Hi John, (Bogstandard2),
                                        My mill/drill is the Warco 'Economy', just about the same as the Axminster ZX25, the Chester Eagle 25, and a few others I guess besides. My view was that it could only be trammed by shimming between base and column and that should last for ages, but, I am indebted to you for attaching the link to your dual gauge tramming tool. What a well written thread! As it happens, I have a couple of gauges going spare, looks like another project to put on the "must do" list!
                                        Cheers,
                                        Chris
                                        #101388
                                        ChrisH
                                          @chrish
                                          John,
                                          Sorry for the delay in reply, but thanks for your kind words of advice regarding my mill. I'm very happy with it and I am sure I can live with and get round it's limitations.
                                          Chris
