MIG welding tips
MIG welding tips
Home Forums Workshop Tools and Tooling MIG welding tips
  • #18281
    Speedy Builder5
      @speedybuilder5
      What size tip for 9mm gassless wire
      Speedy Builder5
        @speedybuilder5
        I have plenty of 0.6mm and 0.8mm MIG tips, but no 0.9mm tips for use with Gassless wire. How big is the hole in a 0.9mm tip (Ie 0.9 + clearance) ?
        Also, my local stockist for gas only supplies a gas mix of 86%Argon / 14% CO2. Is this OK for:-
        1/ welding mild steel
        2/ welding stainless steel (non critical items) with a stainless wire
        BobH
        #269189
        Speedy Builder5
          @speedybuilder5
          I had no response, so just wanted to ask again in case someone knew the answer.
          BobH
          #269193
          Hacksaw
            @hacksaw
            Gas should be good for steel ,dont know about stainless .. Hell ,i've run a broach through a 0 .6 tip to use on 0.8 wire before now ,on a sunday when the shops are shut . Pretty loose , otherwise it jams and birdsnests in the welder ! Heads Up ! Toolstation doing big screen auto SIP mask for £34 and they're good !
            #269196
            John Stevenson 1
              @johnstevenson1
              Just open it out with a 0.9mm drill, as long as the wire feeds it will be OK.
              That gas is good for steel only, for stainless you need pure argon.
              Why would you need gas with gas less wire ?
              #269206
              Speedy Builder5
                @speedybuilder5
                Perhaps I didn't explain enough. 0.9mm tip for gas less wire and gas for Standard wire (0.6mm & 0.8mm). I have to swap the cables about between Gas and Gas less wires.
                Thanks for replies.
                BobH
                #269318
                Garth
                  @garth
                  Use a 0.9 Aluminum tip these allow for wire expansion and will accommodate the softer flux core wire that has knurling marks on it.
                  Reverse polarity for gasless wire
                  Garth.
                  #276940
                  Speedy Builder5
                    @speedybuilder5
                    Answering my own question,
                    0.8mm wire runs through a .8mm tip which has a hole diameter of 1.0 mm Drill #60
                    0.9mm wire runs through a .9mm tip which has a hole diameter of 1.12mm Drill #56 approx
                    BobH
