Micro boring bars and holders
Home › Forums › General Questions › Micro boring bars and holders
  • #333112
    Dave Harding 1
      @daveharding1
      I have been trying to find a supplier of micro carbide boring bars and holders that actually quote the price of how much they cost to purchase for a project I am working on.
      Can any one help.
      #25709
      Dave Harding 1
        @daveharding1
        #333117
        D Hanna
          @dhanna35823
          #333118
          jimmy b
            @jimmyb
            How small diameter and how deep have you got to go?
            Jim
            #333123
              Have a look at MSC they do the Iscar Piccocut mini bars and holders, about £25 a bar and £90 a holder +VAT, page 490 of online catalogue
              #333124
              jimmy b
                @jimmyb
                I’ve made my own holders. Very easy on the round shank type, the “lozenge” shape type, just takes a bit more effort.
                Jim
                #333125
                Old School
                  @oldschool
                  Try this company they do a range of carbide boring tools called Tiny Tools I use the 4mm diameter internal grooving tools and it's very good http://www.protool-ltd.co.uk.
                  #333132
                  Old School
                    @oldschool
                    Just checked the size I use its 3mm diameter and used in a 3.6mm diameter hole.
                    #333156
                    Muzzer
                      @muzzer
                      You still haven't said what you mean by "small". It's all relative – ask any woman.
                      These ones are available down to 1mm hole dia and up to 10mm.
                      Korloy do a system that is available down to 8mm.
                      Murray
                      PS – Old School – thanks for the ProTools link – that's a new one on me and looks pretty interesting.
                      Edited By Muzzer on 21/12/2017 10:47:58
                      #333227
                      SteveI
                        @stevei
                        Hi,
                        The question is not just what diameter bore but also what depth? Some details on that will make a suggestion much easier.
                        For up to 12x diameter long bores of Ø4.9mm and up I've been using some kennametal products. The inserts are proprietary so not cheap but they have sizes from a shank of 4mm,5mm, 6mm that all use the same tips. I've got the solid carbide shank bars second hand and got the tips from fg metcalfe and son. All the major vendors have their own range for this type of thing.
                        For below Ø4.9mm I've been using some of the Carmex "tiny tools". Same as Old School's reference supplies.
                        Steve
                        #333498
                        Dave Harding 1
                          @daveharding1
                          I need to make a bushing the ID is 10mm the OD is 15mm the measurements are critical. Its in stainless steel.
                          #333504
                          Paul Lousick
                            @paullousick59116
                            HSS should be suitable for turning the bushing. Inexpensive boring bars are listed on ebay or grind your own from a piece of HSS bar.
                            Paul.
                            #333509
                              If the hole is 10mm then you hardly need a micro bar, I've got a couple of bars that take CCMT inserts that will fit in there no problem.
                              You have not given the length but these would reach a lot further than a Micro bar would
                              #333526
                              Ian S C
                                @iansc
                                Here's my little boring bar. Piece of 1/4" sq HSS
                                Ian S C
                                #333657
                                Dave Harding 1
                                  @daveharding1
                                  The material that comes supplied for the job has a 4mm bore so I have to machine it out to 10mm ID. The outside diameter is 18 mm and that has to be reduced to 15mm. I think i am sorted now I have invested in Iscar PICCO .
                                  I have purchased a holder and several samples of the miniature boring bars. Thanks.
                                  #333659
                                  Dave Harding 1
                                    @daveharding1
                                    The work piece is approx 12mm in length.
                                    #333661
                                    Muzzer
                                      @muzzer
                                      The words "drill" and "reamer" come to mind….
                                      Murray
                                      #333688
                                      Dave Harding 1
                                        @daveharding1
                                        The 10mm ID hole has to also be 10mm in depth with a stop at the end its not a through hole. The last 2mm retains the original 4mm bore. The whole thing has to be 12mm in length and 15mm OD. All dimensions are critical.
                                        I think I have got it sussed now thanks for the input.
                                        Edited By Dave Harding 1 on 23/12/2017 23:59:43
                                        #333696
                                        jimmy b
                                          @jimmyb
                                          Good to hear its sorted.
                                          Jim
