Micro Bearing Question
Home Forums General Questions Micro Bearing Question
  • #321523
    David Cambridge
      @davidcambridge45658
      Hello all
      I need a bearing that will run at about 15000 RPM, for extended periods, be tricky to get at when running, and on a shaft of 6 mm diameter. I’m a bit stuck.
      Should I
      Give up ?
      Make a phosphor bronze bushing ?
      Buy a good quality micro ball race ?
      Thanks!
      David
      Edited By David Cambridge on 15/10/2017 09:00:35
      #25562
      David Cambridge
        #321532
        Clive Hartland
          @clivehartland94829
          Forget the bronze bushing, I doubt it will stand 15,000 rpm. Search for high speed ball bearings and you may find they are only have 5 ball bearings in them. They only need a small amount of lube. oil not grease.
          #321538
          Ex contributor
            @mgnbuk
            How about ceramic bearings ? A quick Google for a spec on a ZrO2 696 bearing from one manufacturer gave an operating temparature of up to 250 C and 12000 rpm when oil lubricated – other makes may give different specs. & alternative lubrication regimes may help increase the operating speed.
            HTH
            Nigel B
