metric 123 blocks??
metric 123 blocks??
Home › Forums › Work In Progress and completed items › metric 123 blocks??
  • #214876
    Michael Cox 1
      @michaelcox1
      I have just finished making an extended micrometer, see:
      http://mikesworkshop.weebly.com/extended-micrometer.html
      This is based on a design by mklotz.
      It is fine "as is" for relative measurements but in order to make absolute measurement I need some standard precision blocks that are 25, 50 and 75 mm long to provide calibration standards.
      I have some imperial 123 blocks that are certified to 0.0005" but what I really require is the metric equivalent of a 123 block i.e a 25 x 50 x 75 mm block. This would make a good calibration standard for the micrometer.
      Do precision 25 x 50 x 75 mm block exist? If they do who supplies them?
      Any ideas?
      #31105
      Michael Cox 1
        @michaelcox1
        #214877
        John Stevenson 1
          @johnstevenson1
          Mike,
          You would be better off with slip gauges.
          #214884
          Robbo
            @robbo
            How about Stevensons 10-20-40 or 20 -40-80 mm blocks from ArcEuroTrade? Not what you asked for I know,but needs must sometimes
            #214885
            Martin Connelly
              @martinconnelly55370
              I bought some individual Mitutoyo gauge blocks in May.
              611675-131 50mm £33.67 +vat
              611635-131 25mm £25.12 +vat
              Just letting you know the cost if you go this route.
              Martin
              #214888
              pgk pgk
                @pgkpgk17461
                A bit of 'googling' found this (scroll down for the metric ones) **LINK**
                And on aliexpress **LINK**
                pgk
                #214899
                steve de24
                  @stevede2433577
                  Would the outer diameter of ball bearing races serve your purpose? Anyone know what typical tolerances they are ground to? Steve
                  #214903
                  Chris Evans 6
                    @chrisevans6
                    I would just use the Imperial ones you have and a calculator. Job done for no cost.
                    #214905
                      Hi Mike:
                      Google 'micrometer standards' and you will find sources of the little bars with plastic insulating handles that are used to, well, set micrometers. Cheaper than gauge blocks.
                      steve de24
                        @stevede2433577
                        I think Chris has made the most sensible suggestion. Just use 1", 2" & 3" instead of 25, 50 & 75 mm and calibrate the micrometer at the 0.4mm, 0.8 and 1.2mm points on the micrometer scale instead of calibrating using the 0.0 point.
                        #214908
                        Tony Pratt 1
                          @tonypratt1
                          I would go with slip gauges every time.
                          Tony
                          #214919
                          Vic
                            @vic
                            Looking at that tool I wouldn't bother, I'd just use a digital caliper or buy a large Mic. wink
                            #214930
                            Michael Cox 1
                              @michaelcox1
                              Vic, would you care to elaborate why you think the tool is so bad.
                              #214934
                              KWIL
                                @kwil
                                The extending bar is probably too flexible for "precise" measurement? Micrometer frames are usually very stiff.
                                #214939
                                John Haine
                                  @johnhaine32865
                                  Since 1959 the inch has been defined as exactly 2.54 cm so your imperial 123 blocks if made to standard since that date should have precise metric equivalents. Even if before the difference will be so small that you wouldn't be able to measure it.
                                  #214988
                                  Michael Cox 1
                                    @michaelcox1
                                    Thanks for all the responses. They have provided some interesting things to follow up on.
                                    #214991
                                    Vic
                                      @vic
                                      Posted by Michael Cox 1 on 02/12/2015 19:55:38:
                                      Too many ways for errors to creep in. I can't help thinking if it was such a good idea it would have been done 60 years ago. I've also seen lots of cheap second hand Mics available over the years.
                                      #214992
                                      Vic
                                        @vic
                                        Posted by KWIL on 02/12/2015 21:21:58:
                                        Exactly.
