Metals, composition and uses
Home › Forums › Beginners questions › Metals, composition and uses
  • #334595
    Andy Carruthers
      @andycarruthers33275
      Having read many threads in my thirst for knowledge – apart from beginning to understand how little I know – I see references to different metals ie W1, EN8 etc
      Can anyone point me to a simple reference guide which explains the best usage for the most common compositions please? There may be an article I haven't yet found…
      #9024
      Andy Carruthers
        #334604
        JohnF
          @johnf59703
          Andy gooogle Parker steel colour charts and it has steel comparisons and general uses of many steels, if you can’t find it pm me with your email and I willl send it to you.
          There are a great many steels but depending on what you are doing, making you will need only a few and the knowledge of which to choose for what you are doing—-always make sure you mark your materials left over so you can identify they at a later date either colour code or stamp the spec on the bar end
          Edited By JohnF on 31/12/2017 11:53:52
          #334613
          Andy Carruthers
            @John – Brilliant, thanks
            #334725
            Brian H
              @brianh50089
              I find that the Model Engineers Handbook is very useful if you don't want too much information.
              #334735
              Clive Foster
                @clivefoster55965
                Volume Two of "The Racing Motorcycle, A Technical Guide for Constructors" by John Bradley has excellent chapters on the selection and use of various materials in both bar, sheet and tube form. Lots of interesting information on fabrication techniques, stiffness, strength and fatigue too. Obviously the emphasis is on motorcycle construction but that doesn't alter the validity of the information.  Out of print now but well worth reading if you, or the library, can find copy.
                Besides the materials themselves John also provides some useful discussion as to the logic behind the engineering selection of different material selections and useful discussion on supply issues as of 2003. The supply discussion is bit dated now but still something that needs to be considered.
                As has been discussed on another thread a major issue these days is being sure that the material you get is exactly what you are expecting. The old EN designations have long been obsolete as manufacturers specifications so anything you buy as EN XX steel will be a suppliers judgement as to a suitable alternative to a modern specification. Which can vary leading to unpleasant surprises. About 4 years back I bought over 100 ft round steel bar in 3 different sizes allegedly supplied to the same EN number. When putting tool to metal there are clearly at least 4 different varieties of steel in there, randomly distributed between sizes. This mattered little for my purposes in that case but it could be an unpleasant shock to the unwary expecting the new bit of EN XX steel to behave just like the old one.
                Edited By Clive Foster on 01/01/2018 10:10:41
