Metal grade stamps / punches.
Home › Forums › General Questions › Metal grade stamps / punches.
  • #156008
    Chris Denton
      @chrisdenton53037
      Can you buy stamps that have metal grades on them, such as:
      7075
      EN1A
      6082
      etc
      I know you can use single letters but I'd rather have made ones!
      #23372
      Chris Denton
        @chrisdenton53037
        #156016
        John McNamara
          @johnmcnamara74883
          Hi Chris
          Google this
          shaun hill
            @shaunhill88399
            Could give this place a try, i have had a few stamps made here. http://www.diegrave.co.uk
            Edited By shaun hill on 22/06/2014 18:30:58
            #156069
            Chris Denton
              @chrisdenton53037
              Thanks, I think I'll stick with the marker pen due to price though!
              #156075
              Martin W
                @martinw
                Chris
                Why not make a list of all the metals etc you use and then assign each one a single letter/number and stamp each piece with the corresponding character. This way you can identify what the material is by reference to a simple table, which if laminated will be fine in a workshop environment. I use laminated A4 sheets in my workshop for a range of information I want quick and easy access to.
                Hope this helps
                Martin
                #156120
                Chris Denton
                  @chrisdenton53037
                  That's a good idea, I was thinking of using different coloured stickers with tape over them to hold them on and a similar chart.
                  But I think the individual number system is a better idea!
                  #156121
                  Martin W
                    @martinw
                    Hi
                    The coloured stickers, if they can be made to stay on, would be make each type of metal more readily visible and easier to identify in a batch but may require multi colours if you have a wide selection of materials available; e .g. barbers pole for 6082 aluminium etc wink
                    Cheers
                    Martin
                    #156122
                    Chris Denton
                      @chrisdenton53037
                      I could use a series of coloured tape bands like a resistor.
                      #156143
                      Oompa Lumpa
                        @oompalumpa34302
                        I just have a couple of Industrial Metal Paint pens and write on the material as it comes into stock. This is exactly what these pens are for: https://www.cromwell.co.uk/EDD7340110K
                        graham.
