ME Vertical Boiler
ME Vertical Boiler
Home › Forums › General Questions › ME Vertical Boiler
  • #714324
    Kenneth Morrison
      @kennethmorrison16987
      This is probably a long shot,  but does anyone have a copy of the articles in Model Engineer on the construction of a vertical boiler from December 2017 onwards? I have copies of Parts 1 to 6, but there must  be a dozen or more parts. I have checked  with back issues but they don’t go back that far. I have built a few of the small model engines that have appeared in  ME over the years and have run them on compressed air, but have yet to build a boiler. This one looks like a good place to start.  I am also open to other suggestions.
      Thanks.
      Ken
      #714330
        Digital subscription would get you the missing parts.
        #714333
        Kenneth Morrison
          Thanks Jason, I’ll check that out.
          Ken
          #714342
          noel shelley
            @noelshelley55608
            Hi Ken I will have the copies you need, I will have a look in the back bedroom (library ) Can some one come up with Volume and editions ? Noel.
            #714351
            Weary
              @weary
              #714406
              noel shelley
                @noelshelley55608
                Hi Phil, sadly that site states it is only up to 2014 the OP has asked for 2017. Noel.
                #714433
                bernard towers
                  @bernardtowers37738
                  It appears that there are 33 parts in total covering vols 219/220/221/222 and223 so you have a way to go, a digi sub might be the way to go!
                  #714435
                  derek hall 1
                    @derekhall1
                    33 parts! …….Talk about dragging out a “how to build article”!
                    I have Tubal Cains (aka Tom Walshaw) articles in the late 1970s re building a 3 1/2inch and a 5 inch workshop test boiler and these were 5 parts or less if I recall and were aimed at the beginner.
                    Different times I guess….
                    Regards to all
                    Derek
                    #714535
                    John Purdy
                      @johnpurdy78347
                      Ken
                      I’ve sent you a PM.
                      Kenneth Morrison
                        33 Parts??  I think it is geared towards people  who have never picked up a hacksaw or set of files in their lives., never mind a lathe. I have ordered a set of drawings from Kennions for their GLR vertical Boiler which is slightly bigger so that is maybe the way I will go.
                        #714558
                        noel shelley
                          @noelshelley55608
                          If 6″ isn’t to big I have a set of drawings ! Noel.
                          #714627
                          Richard B
                            @richardb44403
                            I have the ME M36 drawing for the 5″ Tubal Cain Test boiler and magazine build + copies of the 2no following articles to build it.
                            If you want them let me know.
                            Richard B.
                            #714873
                            Kenneth Morrison
                              Thanks to everyone who has responded, but I think I will go with a slightly bigger  boiler.  I’m awaiting the drawings for the Kennions Vertical Boiler, I also have the book by Alex Weiss  “Making Small Gas-fired Boilers for Steam Models”. I have built the hand pump as detailed in parts 5 & 6 of the original series, but instead of using steel balls for the check valves I used poppets with O rings.  I have just used it to test a little pot boiler to 80 psi, for another tiny engine I’m building so I think it will  be OK for any bigger boiler that I build.
                              Ken
