Quite a few disadvantages with Copper Sulphate:
- Has to be made up and acidulated with Sulphuric Acid.
- Only works on clean steel, and not all of them!
- Best applied by dipping in a tank for a few minutes, not by brush
- Work should be rinsed and dried after application. Slow.
- Messy & corrosive (acid drips)
- Degree to which the copper coat sticks to the steel varies between flaky and semi-permanent
- Relatively poor contrast between scribed line and the background colour
- Mildly poisonous, you don't want it in a cut or your eyes, or have a pet drink it.
Blue dye marking fluid is fast drying, safer, easily removed (apart from some plastics), and can be applied by brush to almost anything. It makes a fair fist of coating dirty metal. Much less fuss. Mind you, dropping the bottle with the cap off turns you into a smurf. I used to own a mini-lathe painted green and yellow plus many blue camouflage blotches.
Got a recipe somewhere involving ground up chalk and Gum Arabic. I'll see if I can find it.
