Marcher 2 cyl vertical engine
Home Forums Help and Assistance! (Offered or Wanted) Marcher 2 cyl vertical engine
  • #249827
    David Chadwick 3
      @davidchadwick3
      Hello all,
      can any one help on how to time the valve events on the Marcher 2 cyl parallel vertical slide valve steam engine, please.
      This is one of several unfinished projects, and at 69 , although the Doctor has not advised me not to download any long computer programs or buy long playing records, time seems suddenly short.
      All replies gratefully acknowledged
      David Chadwick 3
        @davidchadwick3
        valve timing
        #249834
          As it is a twin high rather than a compound you just time each cylinder as you would a single. As a starting point I would have the eccentriv leading teh crank by 90degrees plus about 5degrees of lead so 95 degrees ahead of crank total.
          J
          #249861
          Circlip
            @circlip
            Check your PM David.
            Regards Ian.
            #249876
            David Chadwick 3
              @davidchadwick3
              many thanks Jason and Ian (circlip) much appreciated
              kind regards
              David
              #272773
              Richard Eversdijk
                @richardeversdijk63841
                Dear Ian,
                Is it possible that I also can have those instructions about the valve setting on the marcher engine you send earlier to another forum member?
                I would be much obliged.
                Kind regards,
                Richard Eversdijk,
                #371161
                Matti Piilola
                  @mattipiilola32835
                  Hello, I am also building Marcher and would like to get the timing instructions, thank you!
