Making Unimat DB/SL Steadies
Home Forums Workshop Techniques Making Unimat DB/SL Steadies
Viewing 15 posts - 26 through 40 (of 40 total)
  • #812981
    Emgee
      @emgee
      If the poster wants a print file joining the Unimat iO Group is a good route to take, download is FOC.
      https://groups.io/g/Unimat
      Emgee.
      SL steady.SL steady
        On duncan webster 1 Said:
        All it needs is a bit of flat to locate between the 2 round bars, which could be done with file and saw, screwed to  a longer bit sat on top, and a 3rd long bit underneath to clamp it all together. No accurate holes of vees. Don’t introduce spurious accuracy.
        You may be ‘technically’ correct there, Duncan … But, as Dave has repeatedly reminded us elsewhere, we should consider needs and wants separately.
        If I was making a ‘fixed steady’ for a Unimat, I would want it to include kinematic alignment with the headstock spindle [which makes the job of setting-it-up for work much easier].
          Duncans method would give 4 long contact points as would two vees so should keep it lined up. Take a look at a Myford fixed steady, If it works for myford then it should also work for a Sl and give the Kinematic alignment desired.
          Emgee is that designed for the Sl as it looks like the U3 type but would still have 3 points of contact and work OK if sized for the round bar SL’s ctr height?
          #813003
            Sorry, Jason … I have difficulty visualising Duncan’s proposal
            I’m struggling to “accommodate” the central feed-screw in that simplistic description.
            Out all day today, so I probably won’t be disrupting.
              Maybe that is why it wa ssimplistic, he was describing a way to locate the steady, clearance in the middle would be upto the builder. Yes you would need to cut a clearance notch or similar for the feed screw just like the third hole if going for the drilled/bored/reamed option.
              Or two small blocks that bear on the outside of the bars would do the same job, screwed on with clearance holes they could be finally tightened up in position so reducing the need for accurate sizing of a central block. Infact given the OPs limited equipment just a single block at say the front would do, so long as you pushed that up against the front bar when setting and again when positioning the steady and leaving the middle clear for clamping bolts. Graver rest would not even need a block, just a flat bar will do and the added ability to swivel it’s position on the bed bars would be a bonus as you would get more versatile positioning of the rest, similar to the banjo arrangement found on woodturning rests.
              #813016
              Emgee
                @emgee
                Updated info: Yes Jason the pictures show the U3 Steady but have found the correct file this morning for the DB/SL steady. Step file opened with Fusion360 to capture images.
                Emgee.
                Unimat-SL-Steady29-Sept-2024..Unimat-SL-Steady29-Sept-2024.Unimat-SL-Steady29-Sept-2024
                #813020
                  For anyone else who can’t think beyond a simplistic description this is how Duncan’s suggestion would work with a bit of common sense applied.
                  steady1
                  steady2
                  Or the outside block option
                  steady3
                  #813025
                    That looks the part Emgee, just need to find that reel of Emco coloured filament. 😉😉😉
                    Looking at that U3 version they seem to have got it the wrong way round as the foot will face away from the headstock meaning you will need excessive tool stickout if the carriage is not to hit the steadies base. My cast one has it the correct way round.
                    #813038
                      Thank you for taking the trouble to illustrate the “simple” solution for the benefit of we dim-wits, Jason
                      I am now more convinced than ever that my proposed use of an extrusion would better-suit the OP’s requirements.
                      If he ever returns, then perhaps we will know.
                      Bazyle
                        @bazyle
                        Just a reminder that there were a lot of articles on using and upgrading this little lathe in ME in the ’70s.
                        eg 1976
                        142
                        3551
                        1284
                        R.L.Tingey
                        A Travelling Steady for the Unimat
                        #813052
                          Or how about this earlier one from 1969, four pins on the outside not unlike the two blocks I suggested
                          pins
                          #813059
                          duncan webster 1
                            @duncanwebster1
                            One block either side of the front bar is even better, bigger aspect ratio so keeps steady square on better. There is no good reason to have a steady bang on centre, you have to adjust the fingers anyway
                            #813119
                            Andy Carlson
                              @andycarlson18141
                              Gosh this thread has certainly woken up again after a month being quiet! … typically while I was away for a few days.
                              Thanks again for all of the suggestions. The job is not yet done but the materials have arrived to do the job with two rectangular aluminium bars and three holes. One thing the Faircut does very well is putting drills through things so I am ok with that. This is also a prompt for me to get my clamping arrangements made less hand to mouth and that is now underway.
                              The actual plan is to cut down a Taig steady and screw it to a Unimat compatible base. A similar base is planned for a hand graver support and another adapted Taig steady with a base to fit my son’s EW lathe. The Taig bits are also now in my grubby mits.
                              I will think about other options for riding the Unimat bars but the multiple block options would likely mean starting with different bar stock than the stuff I have already bought.
                              I am intrigued by the discussion of alignment but searching for the kinematic variety turned up a lot of info on knee surgery so I am not sure what it means for a fixed steady.
                              Regards,  Andy
                              #813126
                                Welcome back, Andy
                                Kinematics:
                                Big subject area, but the basics are very simple
                                I suggest you start here
                                and then, on a much more sober level, proceed to find this on archive.org
                                IMG_0996
                                  For repeatable static mechanical positioning the classic kinematic solution requires ”a point, a vee, and a flat” … but I will leave you to explore that.
                                  [spoiler alert]
                                  The Principle of Kinematic Constraint
