Making a new mill over arm, accurately measuring long distances?
Home Forums Workshop Tools and Tooling Making a new mill over arm, accurately measuring long distances?
  • #315537
    Rainbows
      @rainbows
      So for various reasons I want to make a new mill overarm.
      The current overarm is a cast iron tube with the arbour support cast as one with it.
      The quite thin walled cast iron tube is I imagine less rigid than the solid steel bar used in the alternate set up for my Denbigh mill.
      I want to mount a vertical milling head which means having a new over arm anyway.
      The existing arbour support has no convenient way to lubricate the bearing which is a slug of bronze help in place by 4 screws probably cause the person who made it had the same issue as I do right now.
      I need to find the distance between the hole for the overarm and the hole for the bearing. However the distance between them is something like 182mm, to measure across the overarm and the arbour would be longer. I can't use a mic or even my calipers and I want to be chasing 0.01mm. Considering getting a 300mm caliper for £20 off fleabay so that I can at least get an approximation.
      Anyone know of an old engineers magic trick that can give me a very accurate measurement without resorting to buying a big expensive micrometer?
      Also once I get around to building it I will probably post picture of the new arbour support here too.
      Rainbows
        @rainbows
        #315538
        Ian P
          @ianp
          Maybe me, but I'm not clear which dimension you want to measure?
          Is it the centre distance between the spindle and the overarm tube centreline?
          Can you not miss out the measuring stages and make the overarm fit the main casting, then install it and use the spindle to machine the bearing register in situ.
          Not knocking your skills, but two stages of measurement increase the chances of introducing errors.
          Ian P
          #315539
          Muzzer
            @muzzer
            I think you'd need an extremely ancient engineer to come up with a clever dodge. Realistically you will likely have to measure across outside features of the spindle and overarm, then repeat the corresponding internal dimension – then calculate the average. 300m calipers aren't going to break the bank.
            Something like this wouldn't break the bank. I now have some Shahe micrometers and they seem pretty good. Blame Threadexpress!
            Murray
            #315540
            Tony Pratt 1
              @tonypratt1
              Presumably your mill has micrometer dials? First make tight fitting bungs for the 2 holes, then set up the overarm on your milling table with the centres level, you will need to work out the packing required & the bores at 90 degrees to the column.
              You can then use a DTI to indicate the outside of one bung by raising and lowering the table to get the highest reading, zero the dial.
              Lower the table, move over, noting how far you are moving & do the same on the other bung without moving the DTI dial, when you get the same reading as first achieved note how far the table has moved.
              Use the table movement figures & bung diameters to work out the centres. Hope this makes sense?
              Tony
              #315541
              Ex contributor
                @mgnbuk
                You may get an approximation with a £20 300mm caliper, but you won't be chasing 0.01mm with it !
                Nigel B
                #315544
                David Standing 1
                  @davidstanding1
                  Whereabouts are you Rainbows?
                  I have an accurate Etalon P.Roch Swiss 300mm vernier caliper you are welcome to borrow.
                  It measures .001"/1/50mm
                  Edited By David Standing 1 on 06/09/2017 15:30:00
                  #315545
                  Rainbows
                    @rainbows
                    Heres some sketchbook CAD
                    My idea for getting over the inaccuracy was having the bearing in a block that slides up and down the arbour support. Shim it into position and then securely clamp in place.
                    Re: boring in situ. That was my first through too and would be very good for accuracy but I can't think of any way to hold the support steady while feeding it in. There is no key in the over arm to keep it steady in place rotation wise and unlike some higher-end mills there isn't a rack and pinion to move the arm back and forth.
                    Re: using the lead screw dials. I like the idea but I would need to invest in a coaxial indicator first I think. Other issue is I think the table might be ever so slightly shy of having enough height travel. 178mm according to lathes.co.uk though I could use a parallel to make up the difference.
                    Re: Dave: thanks for the offer how close are you to Macclesfield?
                    Edited By Rainbows on 06/09/2017 15:43:37
                    #315546
                    Bazyle
                      @bazyle
                      If you are thinking of measuring it you have already gone wrong I'm afraid.
                      Make overarm, make support and bore to fit overarm, Fit to overarm.
                      Put sharp centre in spindle and close up the support to sweep it across the centre making a radius mark at precisely the right distance.
                      It's called 'marking off the job'.
                      #315549
                      Rainbows
                        @rainbows
                        Oh damn ok I think Bazyle has got the idea.
                        Keeping hold of a MT 3 centre that doesn't fit any of my lathes was a good idea after all.
                        One last thing though. If anyone has seen the turret of a capstan lathe or the tailstock of some better lathes whats the thing called that locks either the turret tool or tailstock quill in place? Its how I want to fix up the support onto the overarm but now knowing what to call it is bugging me.
                        #315550
                        Ian P
                          @ianp
                          Posted by Rainbows on 06/09/2017 15:41:39:
                          One way to hold the support steady and to feed it in a controlled manner is to borrow the topslide off your lathe, fix it to the milling machine table and attach the support arm to the moving part of the slide. Not to difficult to align things and to adjust the overarm for a nice close sliding fit
                          Ian P
                          #315552
                          Rainbows
                            @rainbows
                            Ah also a very good point. I really need to practice my out the box thinking more often.
                            #315553
                            David Standing 1
                              @davidstanding1
                              Rainbows
                              191 miles, to be precise! That just kyboshed that idea surprise
                              #315584
                              Bazyle
                                @bazyle
                                Posted by Rainbows on 06/09/2017 15:55:25:One last thing though. If anyone has seen the turret of a capstan lathe or the tailstock of some better lathes whats the thing called that locks either the turret tool or tailstock quill in place? Its how I want to fix up the support onto the overarm but now knowing what to call it is bugging me.
                                Cotter pin. As used on bicycle cranks at one time. By the way it is important when making a cotter to think a bit about how it works. Sometimes it is suggested that you fit the pin then drill through the shaft hole to take a curved slice out of the pin that 'fits the shaft perfectly' so will lock it nicely. However what then actually happens is the 'heal' of the scallop taken from the pin dents the shaft as it is pulled up tight. You need a gentle slope as used on those bicycle ones.
                                #315610
                                Rainbows
                                  @rainbows
                                  Ahh I thought cotter pin but when I googled it there was just the hairpin style ones.
                                  Yeah I was about to make it in situ with the rest of the hole. I would have thought the single line of contact in the wedge shape would give more pressure -> more chance of denting? Maybe if I bore it in situ and then file off the small extremity of the pin it will give the best of both worlds?
                                  #315612
                                  Dave Halford
                                    @davehalford22513
                                    Posted by Bazyle on 06/09/2017 15:42:28:
                                    Exactly what I did to re set my Centec way, way waaay out of alignment overarm bearing.
                                    #315613
                                    Tony Pratt 1
                                      @tonypratt1
                                      Posted by Rainbows on 06/09/2017 19:29:25:
                                      Logic dictates that a full contact radius cotter will give a better grip than a wedge, judicious chamfering may be needed to prevent 'dig in'.
                                      I would suggest a wedge cotter is used in most cases as all pins and shafts of the same size will be interchangeable?
                                      Tony
                                      #315614
                                      mark costello 1
                                        @markcostello1
                                        I gave up on bushings on mine and made a new arm with ball bearings, problem solved.
                                        #315623
                                        peak4
                                          @peak4
                                          Posted by David Standing 1 on 06/09/2017 16:21:49:
                                          Rainbows
                                          Rainbows, I however now live in Buxton,which is a wee bit closer to Mac.
                                          I also recently bought a 24" vernier calliper of reasonable quality; that's manual reading vernier, as opposed to new fangled digital electronic stuff.
                                          Drop me a PM for the address and pop over for a brew sometime.
                                          Regards Bill
                                          #315632
                                          steamdave
                                            @steamdave
                                            If you have or can borrow a copy of GHT's book on making the Universal Pillar Tool, he explains how to make a cotter. They are used to hold the arms to the column and column to base.
                                            The Emerald Isle
                                            #315634
                                            not done it yet
                                              @notdoneityet
                                              So what is wrong with the current arbor support? Bore out the over arm innards and fit to a spigot on the new overarm. No real meaurement required. Sort the arbor lubrication with a suitable mod – like an oil hole? KISS Principle working again?
                                              #315638
                                              peak4
                                                @peak4
                                                p.s. as a new post since I can't edit the previous, I could probably come up with an internal micrometer, or a height gauge and surface plate, depending on exactly where you need to take measurements.
                                                Bill
                                                #315648
                                                Rainbows
                                                  @rainbows
                                                  Except for that lip to the left there isn't really any point thats thicker than the over arm so can't bore it out. You can kind of see the bronze lump welded the the original cast part. The 15.85mm bore only goes 16mm in which isn't in my mind the optimum bearing size for the forces involved.
                                                  Mark, how long has your ball bearing been working? My only concern is having the bearing being pressed on and off hte arbour a lot and something wearing away. Not sure what sort of tolerance would give the least interference while still engaging the bearing. I am pretty terrible historically speaking at making bearings fit properly.
                                                  I can't remember where but I saw a guide on the internet ages ago on making cotter pins while restoring a capstan. If anyone knows he one I am talking about it would be handy to have a link for reference and also posterity. Can't say I currently have the GHT book but I have a vague idea how to make them.
                                                  Also thanks for the offer of the somewhat closer calipers :v Been a long long time since I used manual ones. I think they are surplus to requirements now however. Times are a fair bit hectic at the moment, might see you some day though.
                                                  edit: caught out by the secret second page, double thanks for those offers. Though not necessary for the current job its good to know someone generous is close by.
                                                  Edited By Rainbows on 07/09/2017 00:36:30
                                                  #315650
                                                  John Reese
                                                    @johnreese12848
                                                    Here is how you can bore it in place. Clamp the arbor support to the overarm. Leave the overarm clamps loose enough that the overarm can slide. Grab the lower end of the arbor support in the milling vise. Use your Y axis feedscrew to feed the arbor support onto the boring tool.
