Making a dovetail cutter
Home › Forums › Beginners questions › Making a dovetail cutter
  • #8881
    sean logie
      @seanlogie69385
      #318686
      sean logie
        @seanlogie69385
        I’m going to attempt to make a dovetail cutter for the centec2 that will be mounted directly into the spindles mt2 . What would suitable material should I use . Should the cutter be an carbide insert or hss. The dovetail is for mounting the vertical head I’m also attempting to make .
        Sean
        #318710
        mechman48
          @mechman48
          IIRC some time ago I read an article/thread that a member had made a dovetail cutter with a single carbide insert, I believe he made the holder from silver steel. you would have to trawl through the forum posts to locate it.
          George.
          #318712
          mechman48
            @mechman48
