Machining gun metal
Machining gun metal
Home › Forums › Beginners questions › Machining gun metal
  • #376616
    Eric Cox
      @ericcox50497
      When machining gun metal should it treated the same as brass and cut at a high speed
      #9378
      Eric Cox
        @ericcox50497
        #376619
          Gunmetal is generally a very well-behaved metal! It machines better than bronze but isn't as prone to lots of needle like chips as with brass. You are best approaching it as if it was a very free-cutting mild steel and I wouldn't recommend zero-rake flat topped tools that you might use for brass. Because 'gunmetal' covers a lot of ground (generally most copper/zinc/tin alloys there's fair bit of variation.
          Mick B1
            @mickb1
            Many of the bits I make for the local railway are in LG2 – leaded gunmetal. I treat it the same as CZ121 brass and don't meet any issues I can readily think of. Batches are small, typically 4 – 12 components, so maybe I'm not doing enough to expose any real differences.
            #376676
            Thor 🇳🇴
              @thor
              Hi Eric,
              I have machined LG2, and as Mick I run the work at about the same speed as you would for free cutting brass.
              Thor
