I know exactly where Cabinet Enforcer is coming from and, to be honest, I have some sympathy with the European approach. But the men in Brussels do tend towards remarkably selective blindness. You only have to look at the things masquerading as jacks supplied with cars for the last couple of decades and more to consider that there are areas where a bit more applied legislation would be appropriate. The thing supplied with her-ladyships L322 Range Rover (now recently departed thank God) pretty much re-defined inadequate. I'd be worried lifting a pedal car with it. At least my lovely P38 Rangie has a properly strong bottle jack in the back. Admittedly you still have to be careful to ensure it won't tilt but atleast its not going to collapse on you. I'm told the L322 one isn't the worst out there either.
A half decently engineered plug in the side, run up a screw, type always seemed best to me. Lancia did about best of breed for the HPE.
Getting back to the Sky Hook I'd say anyone who couldn't slot that in adequately safely would be dangerous in chage of shoelaces. Realistically the 500 lb load capacity seems far to high for lathe chucks, mill vices, rotary tables et al. 100 or 150 seems more the mark.
When it comes to lathe mounting it needs a T slotted cross slide. These seem to be the norm in the USA but less common in the UK and Europe so less of a potential market.
A work cart mount version is what I'd want as my workshop is too large for Duncans unistrut or similar beam to work sensibly. I'd need about three I think in addition to the two heavy lift crossways RSJs that seemed a good idea when I built it.
A tube bolted to one corner of the work cart with the Sky Hook sat on a similar, slightly smaller one, that could be dropped in when needed ought to work. Worm drive gearbox I think so no need for a brake. Power it from a battery drill via a 10 mm / 3/8 or 1/4 hex spigot shaft. That handwheel would get seriously in the way when storing.
Edited By Clive Foster on 28/05/2020 23:05:22
