Lost key for Simat 101 crank chuck
Home Forums Help and Assistance! (Offered or Wanted) Lost key for Simat 101 crank chuck
  • #380110
    Andrea Giovannini
      @andreagiovannini28573
      Dear friends
      I need your help because I have lost the key of the chuck on my old lathe Simat 101. It is a crank chuck with 72 mm diameter. I am not able to post a picture of it because I am not expert. So I'd like to know if there is a seller willing to sell this key or someone that has one and give me for money.
      I canot use the lathe without this item.
      Please give your suggestions or your help. Thank you
      Andrea Giovannini
      Alessandria Italy
      Andrea Giovannini
        I need help to find the item
        #380123
        Emgee
          @emgee
          Is it a drill chuck type key ?
          If so what diameter are the holes in the chuck where the key fits for opening/closing ?
          Emgee
          #380130
          David George 1
            @davidgeorge1
            Hi Andrea I have a K1 chuck key that has a 4mm nose is that what you need.
            David
            #380136
              Posted by Emgee on 10/11/2018 19:24:02:
              On the other thread **LINK**
              https://www.model-engineer.co.uk/forums/postings.asp?th=138783
              Peak4 provided an useful photo of the key design.
              … I've not seen one like it before dont know It's similar to drill chuck key but not a bevel gear !!
                idea
                See the top-left item on the 'Accessories' here: **LINK**
                http://www.rejon.co.uk/manix_ml210.php
                Edit: Couple of photos of the chuck, on the Record version of the ML210, here:
                https://www.thewatchforum.co.uk/index.php?/topic/63667-finally-some-lathe-work/
                Edited By Michael Gilligan on 10/11/2018 22:47:26
                #380148
                peak4
                  @peak4
                  Posted by Michael Gilligan on 10/11/2018 22:33:43:
                  idea
                  Also on the other thread, Rejon replied to me and said they couldn't supply one; at least that's what I took their reply to mean. indecision
                  Bill
                  #380157
                  Martin Connelly
                    @martinconnelly55370
                    Short term fix might be a strap wrench and tommy bar. I have a small chuck with the outside ring knurled and a tommy bar hole and that is all that it needs for a good grip.
                    Martin C
                    #380163
                      Posted by peak4 on 11/11/2018 00:30:43:
                      [ … ] Also on the other thread, Rejon replied to me and said they couldn't supply one; at least that's what I took their reply to mean. indecision
                      My apologies, Bill … I missed that important point. blush
                        At least I have learned something from this discussion:
                        The geometry troubled me a little, as I have only really considered quite narrow 'contrate' wheels … a little searching revealed that this might be better be termed a 'Crown Face Gear' and that the geometry can indeed be a little complex: **LINK**
                        http://spiralbevel.com/crown_face
                        [ not that I would really expect the gearing of chuck and key to be made to close tolerance ]
                        Grizzly bear
                          @grizzlybear
                          Hi Andrea,
                          Update please.
                          Have you found your chuck key?
                          Bear..
