Looking for a Centec 2 arbor and Mk III head
Home Forums Manual machine tools Looking for a Centec 2 arbor and Mk III head
  • #334907
    Hugh Allen
      @hughallen31308
      Hello. I have bought a Centec 2B, which is basically robust and with very little wear on the ways, but a machine that has been roughly used, with things like large spring washers to replace lock-nuts on the spindles. I have completely stripped the machine and plan to spend about 3-4 months doing a careful rebuild. One question I have is does anyone know where I can get a new horizontal arbor. The one that came with the machine has a badly marked up spindle surface and a very dodgy looking MT2 , with surface scratches.
      I am also looking for a Mk III head. I have a Mk II, which I have reconditioned, but I'd give all the hens' teeth in my collection to get a Mk III in good order.
      Looking forward to replies and thanks
      Hugh Allen
      #13113
      Hugh Allen
        @hughallen31308
        #334918
        Bazyle
          @bazyle
          I think Gloster tooling do a few sizes. About £125. They also advertise on ebay.
          #334948
          not done it yet
            @notdoneityet
            Hugh,
            Scratches on the surface of a morse taper are no particular problem. Just stone off any edges – they don’t need 100% contact area.
            Is the horizontal arbor the original 1” jobbie? You may find that you can use an unworn portion for most jobs?
            I made a 22mm horizontal arbor by shrink fitting a length of round stock into a MT2 blank end arbor suitably machined. Works OK so far.
            BTW, just how many hen’s teeth are you offering? I’ve currently got none at all – which means that if you don’t have any more than I have, you are not offering anything!smiley
