Loctite type question
Home › Forums › General Questions › Loctite type question
  • #329212
    Steve Crow
      @stevecrow46066
      I am looking for some way of securing small screws from vibration etc.
      The screws are steel 12BA going into tapped brass and brass nuts.
      It is important that the bond is temporary, I want to be able to break it without damaging things. It might be asking a bit much but it would help if it was invisible as well.
      Looking at the Loctite website just confuses me more – there are so many different products and I don't know how there properties will scale down to tiny screws. They are not cheap either.
      Would a superglue bond be breakable? Do clockmakers use shellac?
      Has anybody have any suggestions or experience with this sort of thing?
      Many thanks
      Steve
      #25664
      Steve Crow
        @stevecrow46066
        #329215
        Emgee
          @emgee
          Hi Steve
          Threadloc 395 here looks suitable
          Emgee
          typo again.
          Edited By Emgee on 26/11/2017 11:30:14
          #329216
          Tony Pratt 1
            @tonypratt1
            One of the many thread locking products will be what you are after.
            Tony
            #329219
            Chris Evans 6
              @chrisevans6
              Thread lock put on vary sparingly with a cocktail stick.
              #329220
              john carruthers
                @johncarruthers46255
                Thread locker. It can be dismantled, if stuborn a bit of heat helps loosen it.
                I use a dab of nail varnish as a temporary locker.
                #329221
                  For 12BA screws … Loctite 222 is a good place to start
                  http://www.loctite.co.uk/loctite-4087.htm?nodeid=8802623422465
                  Note: The illustration on that page is not particularly helpful !!
                  Edited By Michael Gilligan on 26/11/2017 12:03:06
                  #329230
                  JohnF
                    @johnf59703
                    Agreed Michael but I think 221 low viscosity may be better in view of the thread size.
                    nigel jones 5
                      @nigeljones5
                      I wouldnt put anything with the loctite threadlock logo anywhere near a 12ba nut or bolt, even their very weak bearing retainer is likely to cause the thread to break, I know this from experience. Try a minute dab of clear silicone sealant first is my advice and I use loctite products almost daily.
                      #329236
                        Posted by JohnF on 26/11/2017 13:32:24:
                        Quite possibly, John yes
                        I really wouldn't want to choose beteween them without considering the detail of the requirement and Steve's preferred method of application.
                        At the risk of tempting providence: I happen to have 222 in stock, and I've never [yet] had a problem using it on very small screws.
