Interestingly enough, the rear bar should be a push fit and the front bar should be looser as it slides along between the two end castings.
Professor Chaddock actually set up his Quorn across a surface plate, there should be sufficient movement of the bars so that the assembly dries FLAT.
Someone said that high viscosity 601 is the thing to use. I would have thought a lower viscosity (almost gap filling) would be better. The end pieces that support the bars are almost a couple of inches thick, so maybe getting the Loctite everywhere would demand a somewhat lower viscosity? Just thoughts with no real knowledge of the subject!
Thanks everyone,
Andrew.
Whoops! I misread KWIL reply. He says that it is LOW viscosity for the 601. Should have gone to Specsavers. Sorry KWIL
Edited By Andrew Tinsley on 21/06/2017 12:29:17
