Loco wheel quartering
Home › Forums › Beginners questions › Loco wheel quartering
  • #305563
    Alastair Macpherson
      @alastairmacpherson52003
      I am building my first steam locomotive and have reached the wheel-quartering stage. I have read that it is usual for the right-hand crank to lead. My question is; with the RH crank at IDC, should the LH crank be up, down, or doesn't it matter which?
      #8769
      Alastair Macpherson
        #305574
        Clive Brown 1
          @clivebrown1
          I don't think it makes any difference to the running of the loco, but with the RH piston at rear DC, the LH crank should be down.
          I think that's correct!
          #305738
          Alastair Macpherson
            Thank you Clive; much obliged.
            #305746
              Posted by Alastair Macpherson on 04/07/2017 20:29:10:
              It matters if you are a rivet counter, but beware although MOST locos are as Clive describes, some are not!
              Southam is a diesel not a steamer, but the cranks are definitely 'the wrong way round' on the real thing.
