Lidl sandblaster
Lidl sandblaster
Home › Forums › Workshop Tools and Tooling › Lidl sandblaster
  • #317051
    sean logie
      @seanlogie69385
      My wife Amanda was in Lidl today and she thought I might have use for a wee sand blaster . Well I tried it out tonight on a old cast iron spindle of a water valve (I also got a big chunk of bronze off the same valve ) and it works a treat to my absolute surprise . So if anyone fancies getting one they are on sale now (obviously lol)
      ?12.99 .
      Sean
      Edited By sean logie on 14/09/2017 20:31:28
      #18657
      sean logie
        @seanlogie69385
        #317054
        Brian Sweeting 2
          @briansweeting2
          Slight problem for me on that one, no air compressor – damn.
          #317066
          Mike E.
            @mikee-85511
            I bought one when they were available several years ago, and I can't fault it. I removed the small canister and put a siphon hose on the stem leading to a bucket full of sand; it works a treat.
            #317097
            sean logie
              @seanlogie69385
              Lucky for me ,I was gifted a 200 litre compressor a couple of wks ago . It was supposed to have an intermittent problem ,only problem i could find was the pressure shut off switch was adjusted to the max ,all I did was turn it down to about 90psi never missed a beat since.
              Sean
              #317100
              not done it yet
                @notdoneityet
                Sean,
                Most home-use compressors are either 8 or 10 bar machines – the rationale being that most (decent) air power tools require 6 bar, to operate at full capacity. Some only require 5.5 bar, but that still does not leave much of a ceiling for outlet pressure regulation, even if you have a 200l receiver.
                I think the grit blaster (don't use silica sand) will require 6 bar.
                #317106
                clogs
                  @clogs
                  as a heads up……..
                  out of interest my local Lidal (Bordeaux) has a small wet / oil air compressor…..€109 euro's………about 5cu/ft, 24lt tank…….1.8kw motor and has a built in hose reel with a 10m hose on it…..
                  also there's a selection of hose fittings……..have used these fitting everyday and they do last ….mines over 2 years old…….
                  so I guess it'll be in a store near U quite soon…..
                  I bought a dry compressor from Aldi over 14 years ago and still works a treat although very noisy, it's just as a mobile tyre inflator…….at these prices u can't go wrong…..
                  as for the sand blaster and this compressor, it's not a RACE…..
                  have fun……..clogs
                  #317189
                  sean logie
                    @seanlogie69385
                    Yes the bar pressure is important ,it'c the cfm that makes the difference . Mine delivers 9 cfm so more than happy, and it also keeps up with any air tool i use blaster included ..
                    Sean
                    #317200
                    Clive Foster
                      @clivefoster55965
                      Mike E
                      That syphon hose conversion to use a bucket of sand idea is good. Somehow I ended up with two of that sort of gun, one Lidl and one of another brand so maybe will give it a try.
                      Presumably you can still use the collector bag? I have a stand alone syphon from a bucket one but thats just too messy unless desperate.
                      Fortunately I found a proper Guyson cabinet for affordable money some years back which holds pretty much everything I have to deal with.
                      Clive.
