lever action chuck ?
Home Forums Beginners questions lever action chuck ?
  • #7284
    Rich2502
      @rich2502
      #161968
      Rich2502
        @rich2502
        I acquired a myford lever action chuck with a collet in it from a junk pile, I have no idea what one of these is for, can some one enlighten me ?
        Is it something I should keep for when I get a Drummond lathe, or is it Myford only ?
        #161999
        john kennedy 1
          @johnkennedy1
          Is it one of these? http://www.lathes.co.uk/myfordcapstan/
          Used for repetition work where every piece is the same size. don't know what else it will fit but I would have thought it's a valuable item, especially if its got the M word on it.
          #162017
          Rich2502
            @rich2502
            One of these.
            #162019
            Clive Foster
              @clivefoster55965
              Great time an labour saver if you have anything more than 5 or 6 components to do from same size round stock. Assuming you have the correct size collet.
              As it owes you nothing I'd consider it a keeper and start looking for useful to you size collets at suitably economic prices. As ever wit tooling tho' its a question of budget prioritories as no one can afford everything on the wish list.
              With only one collet its unlikely to sell for seriously useful money. Generally this sort of thing does better as swop fodder.
              #162022
              Tony Ray
                @tonyray65007
                What model of Drummond are you going for and why ?
                I ask as having owned a 1908 model ( still have it but don't use it) I found the spindle bore very limiting. If it were me I would sell the collet chuck and put that and any other funds destined for the Drummond towards buying something more capable.
                #162033
                Chris Trice
                  @christrice43267
                  I disagree. I’ve got one of these and it’s very useful. It has a separate backplate so you could machine a backplate for a different spindle. The only thing you need to arrange is a tapped hole or bracket for the clevis to bolt into. The other advantage with this type is the collet doesn’t pull back into the spindle so repetitious work that needs the same length is easier. If you do sell it, they actually quite high value.
                  #162051
                  Rich2502
                    @rich2502
                    With a full set of collets I’ve seen one for ?190. With all the collets. I’m sure the collets can be made or found.
                    I am looking for a Drummond M, I just happen to like old quality machines, and Chinese stuff just looks cheap and nasty to me.
                    Edited By Richard chucklbutty on 28/08/2014 20:06:06
                    #162117
                    Ziggar
                      @ziggar
                      why has the photo gone???????
                      Z
                      Edited By Ziggar on 29/08/2014 13:59:31
                      #162125
                      Rich2502
                        @rich2502
                        I deleted it on my photo bucket, I didn’t know it would be deleted here as well.
                        #162192
                        Ian S C
                          @iansc
                          Best way for photos on this forum is to open an album on site, you can then move the image to what ever thread you want to. Don't try to load photos that are too big, I reduce mine to 640 x 427 which seems quite adequate.
                          Ian S C
