Level lathe set up
Level lathe set up
Home › Forums › General Questions › Level lathe set up
Viewing 25 posts - 1 through 25 (of 85 total)
  • #312356
    David Thompson 1
      @davidthompson1
      Dear Experts
      Why, when setting up a lathe, is the advice to make sure it is level?
      Wouldn't it be ok if it wasn't level, as long as the bed wasn't twisted or distorted?
      Thanks, David
      #25447
      David Thompson 1
        @davidthompson1
        #312357
        Journeyman
          @journeyman
          David, not an expert but having the lathe level helps when setting it up. As you say though if there is no twist in the bed and no distortion then the lathe will still work at an angle. There are slant bed lathe which are definitely at an angle front to back but probably still levelish lengthwise. I think getting paranoid about level is unnecessary. When I was briefly in the Merchant Navy the lathe in the engine room was rarely, if ever, level. Come to that you had to hang on to it just to keep yourself level sometimes!
          Carl Wilson 4
            @carlwilson4
            Shoot me now.
            #312363
            mgnbuk
              @mgnbuk
              Slant bed lathes are leveled front-to-back using a fixture held in the turret that puts the level errr…. level.
              Sometimes this is provided with the machine as part of the original equipment, sometimes the installation technician brings the factory tool along with him (and takes it away again) or, in my case, you make one when you get a second hand machine.
              When (reasonable quality) lathes are manufactured, the alignments are set with the bed set in a known condition. Setting the bed back to that known condition on installation should, therefore, bring all the other alignments back to the values shown on the inspection record. In the greater (industrial) scheme of things, a precision level is cheap & easy to use, so using one to set the bed level is easy for both machine builder & end user to get to a known condition.
              A 0.05mm/metre level can be obtained from Ebay from £40-ish (Item 272295866038 for example), which isn't a great deal for a precision measuring device.
              Doubtless there will be other posts along shortly extolling the virtues of "Rollies Dad's Method" (whoever Rollie was ?) to set up a lathe & decrying the use of a precision level in the home workshop – to each their own !
              Nigel B
              #312368
              Ian Skeldon 2
                @ianskeldon2
                Firstly I want to point out that I am probably no more knowledgable than David Thompson 1, however David ask yourself this question;
                If I am going to bother making sure that there is now twisting, bending and distortion in the lathe once it is set up, why would I not make sure it was level as well?
                #312376
                Bazyle
                  @bazyle
                  The engineering community need to invent a new word for levelling a lathe when they don't mean levelling it.
                  Like when the first cave man started to knock through an extra door hole but had a tea break after doing the top half. He got tired of explaining to everyone that it was half a door that he hadn't got round to finishing so invented a new word for it which made it much simpler.
                  #312378
                  David Thompson 1
                    @davidthompson1
                    Carl Wilson 4
                    Why write, "shoot me now"? Is this intended as an insult? If you don't have any knowledge on the subject why bother posting?
                    David Thompson
                    #312380
                    David Thompson 1
                      @davidthompson1
                      Dear Bazyle
                      An enigmatic reply. Cavemen? Can you give a less obscure response?
                      David Thompson
                      #312384
                      Alan Vos
                        @alanvos39612
                        From what I have read (there is a lot of it), a straight bed is what counts. Level w.r.t. gravity is a means to that end.
                        So, is there a method for measuring twist when the bed is not level? I figure it can be done using the traditional precision spirit level with the addition of a sine bar and slip gauges. Those take the place of the factory tool mentioned by Ngel B. But that is getting expensive (or an excuse to buy a sine bar and slip gauges).
                        Whichever way you do it, you need to measure using the same surfaces the saddle runs on. If your lathe has a prismatic bed, this gets complicated.
                        #312385
                        Nick Hulme
                          @nickhulme30114
                          Posted by Ian Skeldon 2 on 16/08/2017 19:39:23:
                          Why would you ensure that there was twist in your bed? That's confusing!
                          #312389
                          blowlamp
                            @blowlamp
                            The term simply means that the lathe is level within itself, i.e without twist of the guiding surfaces.
                            It's immaterial to its precision how the lathe is orientated in its environment.
                            #312390
                            Peter G. Shaw
                              @peterg-shaw75338
                              May I refer you to Chapter 9 of Tubal Cain's (pen name of T.D.Walshaw) book Workholding in the Lathe (Workshop Practice Series 15) where he goes into mounting a lathe, and then the reasons for, and how, to set up the lathe.
                              Peter G. Shaw
                              #312392
                              Bazyle
                                @bazyle
                                It was just that the word 'level' when used in reference to setting up a lathe has a different meaning to the usual 'horizontal' or 'flat'. For lathes it means lack of twist and since it can be achieved traditionally using a spirit-level the term has stuck. It causes endless confusion so it would be easier if we had a different word.
                                If you search this site you will find a lot of previous explanations of how to set up without a precision level as the subject comes up for 50% of the newcomers to the hobby so don't worry you are not alone in being confused by this.
                                Too many words or not enough? Bit off topic but I think the whole basis of the opposition to the Euro would have been smaller if they hadn't invented a new word for it and just called it the 'new pound' or 'new franc' etc in each country then people wouldn't have seen it as so alien.
                                On the other hand I wish gays would invent another word for their partnerships and then all this whining about making their marriages legal would be a lot simpler.
                                #312394
                                David Standing 1
                                  @davidstanding1
                                  Posted by Nick Hulme on 16/08/2017 20:20:24:
                                  Unless your comment was tongue in cheek, Ian obviously had a sausage fingers moment and typed 'now' instead of 'not' wink 2
                                  #312400
                                    My take on levelling is that it's a basic engineering tactic used to simplify construction. Buildings are levelled, roads are levelled, drains are installed at an angle to a level, distances are measured on a level, and machine installations are levelled. Levelling provides a reproducible reference both for the base and the verticals.
                                    The construction, which could be a lathe, is designed to ground it's own weight and loadings without the forces involved causing the structure to bend or topple over. This is most easily done by reference to a level. It follows that an object designed with reference to a level should be installed to match the design so that the installation can be checked.
                                    Levelling also provides a reference for ensuring alignment of parts during assembly. This is particularly important with any construction that's liable to bend. Everything bends, a big expensive lathe is likely to be more vulnerable to bending than a mini-lathe because the latter is short and stubby. Some machines require more care than others.
                                    Another reason relates to balance: off-centre installation may cause vibration.
                                    In the case of the average lathe, once it's installed, I don't think it matters much if it's operated off level. Lathes are used successfully at sea.
                                    KWIL
                                      @kwil
                                      The Slant Bed lathe (example Willson Lathe Company of Halifax) was a means of using a larger swing over the bed, the spindle being set further back.
                                      Nevertheless the bed is "level", albeit at a downward inclined angle front to back. (Hence jig Nigel B mentioned earlier above).
                                      The axes of a lathe need to be set up true to each other, not of necessity in relation to any other plane. We have called it " levelling", Set true might be a better term?
                                      #312402
                                      Russell Eberhardt
                                        @russelleberhardt48058
                                        Posted by Alan Vos on 16/08/2017 20:16:56:
                                        Google "Rolly's Dad's Method" for the simplest method.
                                        Russell
                                        #312406
                                        Carl Wilson 4
                                          @carlwilson4
                                          Hello David Thompson.
                                          I do have some knowledge on the subject. Not a lot, I admit, and probably not as much as many of the luminaries hereabouts.
                                          My posting was intended to be taken with a certain degree of levity. The subject of lathe set up and levelling has been done to death and invariably results in a bun fight between respective camps on whose method us the best.
                                          My words were intended as a bit of a laugh, a sigh and a “here we go again…”
                                          I’m sorry if that didn’t come across.
                                          Carl Wilson.
                                          #312407
                                          mgnbuk
                                            @mgnbuk
                                            You lot are slacking – 16 posts in before "Rolly's Dad's Method" came up !
                                            Buy or borrow a proper level & do it right.
                                            £0.02
                                            Nigel B
                                            #312424
                                            Ian P
                                              @ianp
                                              Nigel
                                              Is Rolly's father a different person to the Rollie you mentioned in your first reply (third not sixteenth post) to this thread?
                                              Ian P
                                              #312426
                                              Hopper
                                                @hopper
                                                Be aware though that the text book levelling method for setting the bed of a lathe straight may well not work on an old worn lathe that is missing some "thous" of metal off the bed in various places due to wear. It is enough to throw a sensitive level off. With an old, worn lathe, you might as well go straight to turning a test piece (no tailstock centre used) and use that as your guide.
                                                I actually like to set my lathes at an angle so the coolant runs down the little hole in the back corner and down into the tank.
                                                #312463
                                                Russell Eberhardt
                                                  Posted by Nigel B on 16/08/2017 21:35:09:
                                                  £0.02
                                                  Nigel B
                                                  No need to be like that Nigel. I was just answering Alan's question. Not everyone wants to spend out on a precision level that they might use only once. The object of "levelling" a lathe is to ensure that it turns parallel. There's more than one way to skin a cat.
                                                  Russell
                                                  #312465
                                                  Russell Eberhardt
                                                    Posted by Ian Phillips on 16/08/2017 23:00:33:
                                                    Nigel
                                                    Ian P
                                                    I think that was due to the spelling (or memory) error in my post blush
                                                    Russell
                                                    #312469
                                                    Rick Kirkland 1
                                                      @rickkirkland1
                                                      Hoppers post is really heartwarming. I now know two people (including myself) who realise that there is absolutely no need whatsoever for a lathe to be level. The only requirement is that tha ways are flat and true in and on one plane rather than twisted or under torsion. If you doubt the veracity of this just take a look at a CNC machine with the bedways at 45 degrees to the vertical. There ain’t no way that position can be called level.
