Lawn weed and feed. How much is 35g?
Home Forums The Tea Room Lawn weed and feed. How much is 35g?
Viewing 25 posts - 1 through 25 (of 31 total)
  • #466119
    Simon Robinson 4
      @simonrobinson4
      Hi
      I have some Evergreen 4-1 lawn weed and feed. It says use 35g per square metre, but doesn’t give any idea how much that is. I don’t want to use the kitchen scales to measure it as it contains weed killer. So approx how much is 35g? How many table spoons? Or what kind of container would 35g fully occupy.
      Id thought of measuring 35g of sand but it’s a different density.
      Ps My lawn is too small to warrant getting a spreader.
      #35869
      Simon Robinson 4
        @simonrobinson4
        #466122
        Brian H
          @brianh50089
          Can you put a plastic bag on the scales and then measure out the Evergreen into that, being very careful of course?
          #466123
          Paul Rhodes
            @paulrhodes20292
            I would have thought that you take the stated weight of the packet you have and work out how many 35gs are contained therein. Or read how many sq metres your package covers and estimate from there. You would be close enough for government wok ,as the saying goes.
            #466126
            Martin Connelly
              @martinconnelly55370
              Is it liquid? If so then 35g is 35cc if it is similar density to water. 20mm x 20mm x 90mm is 36cc.
              Martin C
              #466128
              Speedy Builder5
                @speedybuilder5
                a letter with 3 sheets of A4 is about 20grm
                #466130
                Tony Pratt 1
                  @tonypratt1
                  Just weigh itfrown
                  Tony
                  #466141
                  pgk pgk
                    @pgkpgk17461
                    A standard plastic teaspoon is 5ml. Of course it depends on differing density but itls not going to be that critical unless you start marking your lawn out in metres squares.
                    Just work out the roug area of lawn, total feed required. What proportion of the pack that is and eyeball it.
                    pgk
                    #466142
                    DiogenesII
                      @diogenesii
                      Dosage rates for items to be broadcast are often given for a handful, quite literally – so it'll probably be about as much as one can easily take out with one (smallish) hand..
                      If you put some non-treasured container on the scales and set the tare, you will be able to put a handful in and see..
                      ..wear gloves..
                      #466152
                      Nigel Bennett
                        @nigelbennett69913
                        Whatever you do, don't spread it in such a cavalier fashion that the top comes off the container and you splatter the entire contents over a very small area. If you do this, the grass dies and it takes a lot of effort to regrow it. Don't ask me how I know this….
                        #466155
                        DiogenesII
                          @diogenesii
                          ..Nigel, SShh ..You'll be pestered with Spam from American legal practises offering to sue Bayer for you.. I am, daily..
                          #466156
                          Martin Kyte
                            @martinkyte99762
                            Maybe you should start from the area of grass you want to treat. For example a 14kg bag of weed and feed I just looked at will cover 400 sq metres. If for example you have 250 sq meters you need a little over half a bag. I use the stuff fairly frequently as I have a lot of moss to deal with and it's fairly forgiving so long as you spread fairly evenly.
                            regards Martin
                            #466182
                            not done it yet
                              @notdoneityet
                              No guarantee, but many of these type of things hold a dose in the cap. Especially if it is in liquid form. Weigh the container and pour out some into a separate receptacle, then weigh again?
                              I think the OP is not thinking this through clearly. Lots of ways to dispense chemicals in one form or another. Several options already mentioned above.
                              #466198
                              Nigel Graham 2
                                @nigelgraham2
                                It's worth considering if you can do this by weighing in one go, the total of Evergreen for the lawn area. This will depend to some extent on how it's applied – as dry granules or a solution in water.
                                35g is barely an ounce and a quarter, so weighing it accurately is easier if in a larger amount.
                                You could also find some suitable container you can level-mark indelibly with the correct amount of that chemical, once established, for repeat use.
                                If you use a lot of garden additives by weight or volume, see if you can buy a low-cost scales and measuring-jug in your local shops that can open. Keep them in the shed or green-house!
                                #466258
                                Ady1
                                  @ady1
                                  Posted by Nigel Bennett on 21/04/2020 17:34:25:
                                  lol
                                  my dad spread it too thick in my folks back garden years ago
                                  agent orange all over the place… my mum was not amused
                                  #466261
                                  Ed Duffner
                                    @edduffner79357
                                    I use Evergreen and generally take an aerosol cap, fill it about half way and sprinkle that over a 1msq area. Use a larger bowl to pour the stuff into first. It's easier to scoop into as you go.
                                    Ed. I need to get some, the weeds are sprouting fast this year!
                                    #466303
                                    Gerard O’Toole
                                      @gerardotoole60348
                                      I just measured 35g lawn feed and it 2/3rd filled a 60ml cup – so approx. 40ml container.
                                      I took a photograph but not sure how to attach
                                      #466359
                                        Posted by Gerard O'Toole on 22/04/2020 13:38:27:
                                        I was going to say that if you used 1 teaspoon = 5g you wouldn't be far out, and the exact amount is far from critical, within broad limits plants will take what they want.
                                        Biggest hazard is a lawn that grows into a jungle… personally I think only masochists fertilise their lawns!
                                        Grindstone Cowboy
                                          @grindstonecowboy
                                          As an aside, I successfully made some weedkiller the other day with white vinegar (or non-brewed condiment as it is unappetizingly labelled), a squirt of washing-up liquid and three teaspoons of Epsom salts. This filled a spray bottle, and it seems to work best on dandelion type weeds with fleshy leaves.
                                          #466393
                                          John Paton 1
                                            @johnpaton1
                                            I seem to recall that vinegar and bicarb of soda kills weeds (and grass) well – at least my dad reckoned it did after I was caught doing a spot of rocket launching from the back lawn.
                                            #466431
                                            Hopper
                                              @hopper
                                              Just put some in a ziploc plastic bag sealed up and weigh it.
                                              #466433
                                              Enough!
                                                @enough
                                                Why complicate it? Paul Rhodes above has the best idea. just calculate what proportion of the bag is need for your lawn and spread that. (It ain't critical – you can eyeball that much).
                                                #466436
                                                Hopper
                                                  @hopper
                                                  Indeed.
                                                  #466447
                                                  Sam Longley 1
                                                    @samlongley1
                                                    Ask the local drug dealer to do it for you. He will probably bag it up in nice little bags for you if you ask him nicely. You could let him have some to bulk up his ganga as payment. Just do not let the local plod catch you driving home with the bagssurprise
                                                    #466450
                                                      [quote from various sources]
                                                      By hand , apply a max individual dose of 35g per square metre (1oz per square yard)
                                                      May be worth noting the max ^^^
                                                      MichaelG
