Posted by Philip Rowe on 05/04/2018 17:04:57:
Strangely that is a technique that I had considered but I don't have any experiences of using these small grinding points and to be honest I don't think I have ever seen one just 2mm in diameter.
Phil
Yes that is correct, especially where "stones" are concerned, like aluminium oxide or corundum. But there are very small diamond coated bits you can get. Perhaps they don't have the rigidity without a steel shank like the diamond ones.
PS. I got a decent "hilda" branded router drill off of banggood.com that can do 40k rpm, which would be necessary for such a small bit, that came with a load of small diamond grinding bits, was the best part of £30, but I would only do that if you were confident it was the only way. Don't spend money if you don't have to!
As for the validity of your suggested method, I don't see why it wouldn't work, just make sure to keep the RPM lowish for stainless on the lathe or it'll wreck the tool.
Michael W
Edited By Michael-w on 05/04/2018 17:20:36
