What size are the parts? You can get gauge plate upto 300mm wide 1 to 50mm thick which could well be cheaper than buying a 2 x 1m sheet. Subject to the minimum size they can place on the machine.
Most cutters will post small parts or use couriers if larger so location is unlikely to be an issue.
