Laser cutting recommendation
Home Forums General Questions Laser cutting recommendation
  • #23490
    Eric Cox
      @ericcox50497
      #163343
      Eric Cox
        @ericcox50497
        Can anyone recommend a company to laser cut 3/16" aluminium frames based on quality, price and turn around.
        #163351
          Its not so easy to laser cut aluminium due to the fact it can reflect the laser beam, water jet cutting may well be better, have a word with Sciss I've used them several times.
          J
          #163354
          John Stevenson 1
            @johnstevenson1
            Modern lasers can pi$$ 3mm aluminium with no problems and at 1/3 the price of water jet cutting due to the speed.
            Would help if Eric said where he was in the country.
            ESP at Rotherham regularly cuts 20mm alloy with laser and has a page here.
            John McNamara
              @johnmcnamara74883
              Hi Eric
              Yes Aluminium can be cut with a Laser. and with a good finish too… there is little undercutting compared to water jet cutting. Tolerances can be held tighter and it costs less. Some Machines can also laser cut brass alloys Like Salvagnini Fibre Laser cutters **LINK**
              There may be a few older machines around that cant cut Aluminium. however many Can.
              Boiler Bri
                @boilerbri
                Lazer cutting depends on the gas that they use. My mind escapes me as to which gasses!!!
                Bri.
                #163374
                Bob Brown 1
                  @bobbrown1
                  I have used this lot in the past, they have an on line quote system where you upload a drawing and you get to see the cost break down re more is cheaper.
                    Don't forget Model Engineers' Laser.
