There is an additional hole for the right hand tumbler plunger in row 2 an inch and a half or so below the normal hole.
That is the neutral position as the tumbler gears are out of mesh with the Norton screw cutting gear cone and cannot drive it. Instead it meshes with the drive gear of the power feed drive rod. Feeds are selected via the left hand tumbler so the feed range is less comprehensive than on lathes that drive both leadscrew and feed rod via the Norton cone. See the bottom picture on this page **LINK** which shows both hole and the instruction plate. The manual is not perhaps as clear as it should be.
You aren't the first person to be confused. Generally you don't expect a neutral position in a screw cutting gearbox as normal practice is to provide some way of disconnecting the drive. Whether by separate lever or simple dog clutch.
Judging by the one I had limited experience of the Kerry is good machine.
If the clutch action is iffy or unpredicable verify that the shaft carrying the clutch isn't moving sideways when the clutch is operated. The one my friend had suffered from this because the welch plug holding the right hand bearing in place had become a little loose allowing the bearing to shift sideways in the casting. Press fit of the bearing was tight on the shaft and light in the headstock. Just light enough to sometimes let the bearing move. He fixed it with a suitably stepped alloy cover held by three socket cap screws.
That was one of the older, Mk2 ones with a simple pluger lever to select feeds rather than the excellent gate pattern shifter used on later Mk3 machines. My friend found that the innards are sufficiently similar between older and later machines that DIY conversion to the gate pattern shifter is possible using simple, easily made, parts.
Edited By Clive Foster on 22/10/2019 19:30:09
Poxy auto spell correct won't leave some correctly spelled words alone!!!
Edited By Clive Foster on 22/10/2019 19:48:34
Edited By Clive Foster on 22/10/2019 19:55:12
