Just bought a S/H Warco WM250 it will not start!
Home Forums Manual machine tools Just bought a S/H Warco WM250 it will not start!
  • #206529
    Dave Smith 14
      @davesmith14
      Hi
      My first post on the forum. I bought a 2 year old Warco WM250 lathe earlier in the week ( its in in great condition and has been enhancec with proper bearings etc). Obviously it was working when I bought it and all we did to load it in the car was to unplug it trip the trip isolation switch, then remove the tailstock, splash tray, rear splash tray and the chuck safety guard. The chuck safety guard switch has been imobiised by the previous owner. It is still on the garage floor but l plugged it jn this morning to show my wife that it really is quiet but it will not start, it does not appear to be getting any power? I presume that the orange lens between the start and stop buttons should light up if the lathe is plugged in and isolation switch set to on., because nothjng is lighting up. To activate the isolation switch I have rotated it in the direction shown on the switch button and allowed it pop up, but nothing appears to be powering up or run. I hope I am just doing something stupid and that the someone will point me in the correct direction.
      Thanks in advance
      Dave Smith 14
        @davesmith14
        #206533
          Check the gear cover has not been pulled away from the headstock, there is an interlock to stop the lathe working if you remove the cover.
          Do you know how the chuck gaurd was imobalised? the easiest way is to just take the gaurd off the shaft but rotating teh shaft as if opening the gaurd will stop the lateh working, try turning it anticlockwise. I did teh same with mine and could not get it to start last week after a good clean up, I had turnd the mounting shaft while cleaning.
          There is a small quick blow fuse on teh back of the head check that has not been knocked.
          J
          #206535
          mechman48
            @mechman48
            +1 Jason's comments;
            Also check that the tab on the gear cover has not been bent back during transit so it isn't making contact with the interlock at the bottom rear of gearbox, also check both quick blow fuses, the one on the back of the head plus the one on the top next to the emergency stop button.
            George
            #206538
            Dave Smith 14
              @davesmith14
              Gents
              Thanks for the quick feedback, it was the gear case interlock that was the problem, all is fine now. I think George was correct in that the bracket may have been bent.
